Got a 5x86-100GP and a VL/I486SV2GX4 for FREE
First post, by Synoptic
I also got a VL/I-486SV2GX4 2.0 and many other things.
Now, I cannot get the CPU to work properly. Can anyone with that motherboard and CPU combo please tell me what to set ? I have the manual, but anything I dial-in with the jumper makes the CPU show as a 487 at 66Mhz regardless of the actual CLK chosen (50 or 33).
Reply 1 of 25, by Synoptic
I just removed the 27C512 and flashed the latest BIOS i found on vogon on a SST28SF512 and voilà ! The CPU is now correctly detected !
Still not sure though for the setting as there is seem to be some options available for the internal L1 cache of the CPU.. ? So, i'll take any advice anyway regarding my combo.
Reply 2 of 25, by Synoptic
I get a "Get Configuration failed" after the Floppy seek. The computer will also hang trying to boot. The floppy will work, but then it freezes....
Reply 3 of 25, by feipoa
This can happen sometimes when,
a) your floppy controller chip has gone bad. Try using an ISA diskette controller card as a test means
b) your BIOS settings are incorrect, particularly if your cache/memory timings are too fast
c) the incorrect voltage is supplied to the CPU or the motherboard jumpers are incorrect
d) I've recently come into contact with a motherboard which needed the L2 cache to be set to write-through when a Cyrix 5x86 chip was used. Problems occured during floppy boot when DOS device driver for a SCSI card would hang. AMD X5 chips was ok with L2 cache set to write-back.
e) the floppy cable is not in the correct position. Some BIOSes insist that the A floppy drive be installed on a certain position on the cable. I don't recall if it is the middle or end of the cable.
f) a bad floppy drive
g) a multitude of other reasons.
Reply 4 of 25, by mwenek
Are you certain the CMOS battery has enough charge left? I have been struggling with an older socket 3 motherboard, it posted, etc all the way to hanging on the floppy seek. Then I grasped at a straw, bounced the negative side of the battery against a good one to push some charge forward and it booted just fine (albeit with a super weak battery I will have to replace soon).
Win98SE Box: PIII 850, 128MB, 8 GB HDD, CL Live!, ATI 9600XT, 2x Diamond Voodoo 2 8MB
DOS Box: Intel 80 Mhz P24T Socket 3 OD, 16MB, 128MB CF Drive, Number 9 VLB, SiiG VLB IDE, SoundBlaster 16 ISA/WaveBlaster
Reply 6 of 25, by Synoptic
feipoa wrote:
This can happen sometimes when, a) your floppy controller chip has gone bad. Try using an ISA diskette controller card as a tes […]
Will definitely check ca he setting and proper cpu settings. But the manual is not very verbose at this.
The mobo does not have an on board controller, but I will try a different controller card.
Anyone having experience with the VL/I-486SV2GX4 please chime-in.
Reply 7 of 25, by vetz
I have the VL/I-486SV2GX4. Never seen this problem before. My guess:
1. Bad controller card
2. Incorrect jumper settings
There are loads of threads with much information regarding that board here on Vogons. Finding the jumper settings should not be hard.
Reply 8 of 25, by Synoptic
I changed the controller card, got rid of the Get configuration Failed message.
I just realized that my Controlelr card I tried at first is a promise one and seems to be configurable in someway I guess.
Still cannot boot, will try the jumper settings.
Reply 9 of 25, by Synoptic
Allright, foudn it. DRAM timing ! I set it back to default and put everything to slow and now it boots.
The Promise IDE cache card seems to work now ! I can get into the config menu.
Reply 10 of 25, by Synoptic
Well, the system is very unstable. Maybe it is because I put the bus speed to 50mhz and the cache controller cannot keep up. Maybe its my cpu cooler that is doing a poor job?
I'll put the bus speed to 33 and try again my tests.
Reply 12 of 25, by feipoa
I always take my FSB down to 33 MHz for troubleshooting.
Reply 13 of 25, by Synoptic
vetz wrote:
Your IDE controller with cache is VLB based, right? If that is the case it probably has problems with 50mhz FSB on the bus.
I doubt its the CPU cooler as the 486 CPUs require very little cooling.
Correct, VLB. I have two cache controller of not the same brand available.
Reply 14 of 25, by Anonymous Coward
Running a disk controller above 33MHz on VLB is always going to be a problem. Best to avoid that situation.
Reply 15 of 25, by Synoptic
I found another culprit. My L2 Cache configuration.
I am not sure why, but I'll remove all the cache chips and ask help from you guys by showing you the picture of what I have available and then make a combination of something that will work.
Reply 16 of 25, by LunarG
Off topic, but I hate the expression "full retard". It's sounds so childish and lame.
Good luck with the system though 😀
WinXP : PIII 1.4GHz, 512MB RAM, 73GB SCSI HDD, Matrox Parhelia, SB Audigy 2.
Win98se : K6-3+ 500MHz, 256MB RAM, 80GB HDD, Matrox Millennium G400 MAX, Voodoo 2, SW1000XG.
DOS6.22 : Intel DX4, 64MB RAM, 1.6GB HDD, Diamond Stealth64 DRAM, GUS 1MB, SB16.
Reply 17 of 25, by Synoptic
Changed the title for you , sir !
Reply 18 of 25, by Synoptic
I am still very unsure of the CPU jumper settings. the CPU will work, but it seems very slow.
The Cyrix 5x86 is not listed in the cpu settings in the manual. I wonder if anyone could help me on this. Should I use the same setting as an AMD ?
I managed to fix the Cache chip, worked around a defective diskette, decided to trash the cache controller as they both seems to give me trouble and are incompatible with CDROM drives.
I'm close to my goal, I just need to figure the best jumper settings for my Cyrix 5x86-100GP
Video of it being slow : http://youtu.be/r93mVB1FmsA
Reply 19 of 25, by Anonymous Coward
I disagree. I like the expression "full retard". It sounds much better than "full developmentally disabled"
