First post, by Kreshna Aryaguna Nurzaman
So, I've bought a Yamaha RX V-663 receiver from ebay, which is descibed by the seller as "Excellent shape. No scratches. See pictures for details" and "Excellent working condition". The seller has 100% positive feedback.
Now the item has arrived from the Post Office, and I have received the receiver (no pun intended).
Physically, the receiver is in mint condition - almost like new! Save the front-left plastic feet that was apparently broken during S/H. Despite the seller's 100% positive feedback, he is a very lousy packer. Yes, he use double boxes, but he put nothing but used newspapers and Wal-Mart brochures as filler. 😵 No bubble wrap, no foam, nothing. And I thought I'd be lucky if the receiver is still working.
So, I'm testing it in my garage using four old loudspeakers (two Kenwood and two Hitachi) and my Lenovo B460 laptop; Intel Core i5 M520 @2.4 GHz, 4 GB of RAM, and nVidia GeForce 310M with nVidia HD Audio through the laptop's HDMI output. Oh, and a heavy-duty Matsunaga stabilizer/transformer with 1KVA capacity. So I'm good to go.
The menu is working without problems, the remote is working too. Front L/R channel and surround L/R channel are working too. I haven't tested the center channel, the surround back channel, and the subwoofer channel, since I'm going to use 4.0 configuration with full-range front (JBL 120Ti), but I guess since the front L/R and the surround L/R are working, then I see no reason why the remaining output channel shouldn't be working.
The receiver's menu seems to be in good working order. I'm too lazy to test every single function, but I have manually configure my speakers (CENTER OFF, SURROUND BACK OFF, etc) as well as their SPL level (more output for the rear, less output for the front). Yamaha DSP seems to be working well too, and I've quite enjoyed Mozart's Eine Kleine Nachtmusik in Munich and Vienna concert hall. 😉 DPL seems to work great. I also tested its Video Aux stereo analog input with my laptop's stereo-mini analog output, and everything seems to work well.
I've noticed certain things though:
(1) when using HDMI, the sound tends to stutter (with the HDMI lights blinking on the receiver's front panel), especially when I opened resource-hogging applications (like Firefox). I would blame the nVidia's HD Audio driver though.
(2) when using HDMI, I could never get Dolby Digital to work in movies. I have tried both torrent downloads and legally-purchased DVDs, as well as Windows Media Player and Media Player Classics. Still, I cannot get neither Dolby Digital nor DTS through HDMI. The receiver always shows PCM no matter what. On the other hand, the RX-V663 manual clearly states that its HDMI input supports PCM, multichannel PCM, bitstream (DTS and DD), and bitstream HD (stuff like Dolby TruHD or such).
I wonder if it's the fault of the media players, nVidia HD Audio driver, or the receiver. I hope it's not the receiver's though. 🙁
(3) when using its stereo analog input (the video AUX), the unit emits ugly hissing sound if I choose anything other than Pure Direct mode. Only in Pure Direct mode the hissing sound disappear. Damn, it's like going back to the tape era. 🙁
So what do you think?
Anyway, some pics:
10358568_10204914385205878_6016567406439048967_n.jpg?oh=5ba260f99ca78c10dca9340025d2bb80&oe=5472E917
10420749_10204914363645339_6213105204413529606_n.jpg?oh=a3511a649db576007e7fe1cca1e5c2ad&oe=545EA0F0&__gda__=1416287753_872074764b4c23d6a4d57d728ce8e71c
Kreshna Aryaguna Nurzaman.
Reply 1 of 34, by Kreshna Aryaguna Nurzaman
Ah, so I guess I've found the reason why I cannot get surround sound through HDMI without resorting to DPL/DPLII or CinemaDSP.
So I guess I have to enable multiple speakers from nVidia HD Audio Advanced settings. In the picture above, I choose Quadraphonic speakers from nVidia High Definition Audio => Advanced Settings, then the surround speakers start sounding in the AV receiver's Straight Decode mode. The receiver's channel input lights indicator also shows four channel input as well (L/R and SR/SL).
However:
(1) the nVidia HD Audio driver insists to send multichannel PCM to the receiver. I tested it with Skyfall DVD and selected Dolby Digital from the DVD's root menu, yet the receiver keeps showing PCM instead of DD.
(2) the amount of stuttering worsens considerably. DVD movies like Skyfall stil sounds normal, but compressed video (like .AVIs or .MP4s) stuttering so bad that it's unplayable. Games like WarCraft III falls somewhere in-between. During gameplay, the stuttering is still manageable, but during in-game movies, the stuttering becomes severe as well.
Anyway, the stuttering increases with the number of applications I open, like Firefox and Photoshop. Sometimes the stuttering becomes very severe even in DVD videos, that I have to restart the laptop to make everything normal again.
So I guess it's nVidia HD Audio problem instead of the receiver, am I correct?
Reply 2 of 34, by Kreshna Aryaguna Nurzaman
D'oh! I was a fool.
Yep, using Dolby Digital reduce the stuttering greatly.
Reply 3 of 34, by obobskivich
Maybe too late now - but sounds like all of the issues are on the computer's end in terms of HDMI. There's nothing wrong with it spitting out PCM in concept though, and it probably defaults to that for compatibility (remember a lot of early HDMI gear only did PCM).
Reply 4 of 34, by Kreshna Aryaguna Nurzaman
Ah, so the receiver is in good condition I think. Glad to hear that. 😀
Well apart from the hissing problem, I haven't found anything wrong with it. Yes, HDMI stutters badly, but I also think it's the fault of nVidia HDMI driver, especially since the stutters become more severe whenever I open resource hogging applications like Firefox.
Anyway, will such stutter eventually damage the receiver's HDMI end?
Reply 5 of 34, by Jepael
Well I have experience with Yamaha RX-V640RDS and some Sony amp, and I can safely say if you have a PC involved then it is definitely the PCs fault.
And no, stuttering does not break the HDMI input of amplifier, it just transfers bits and tries to lock on to the audio samples and it can't and the audio DAC chip outputs stuttering analog signals and that's fine as well. However, I cannot say what the power amplifier or your speakers will like about that in the long run, trying to reproduce the noisy transient-filled garbage that does not resemble a real-world audio signal. I haven't broken anything yet.
Reply 6 of 34, by Kreshna Aryaguna Nurzaman
Why does the HDMI stutter when sending PCM? Especially, why does the stutter become worse when I open resource hogging application? The laptop is newly installed, by the way. It doesn't even have Office yet, and the CPU is i5. Is nVidia HDMI implementation really bad or what?
Reply 7 of 34, by Kreshna Aryaguna Nurzaman
Ah, dang it it! It seems Yamaha receivers have incompatibility problems with certain devices. It's not the fault of this particular Yamaha receiver I've purchased, it seems. The guy on the thread has tried RX-V465 and RX-V565, and experience similar problems.
I remember a year ago. I haven't reinstalled my laptop at that time, so the laptop was burdened with resource-hogging applications, antivirus, dirty registry, and heavily fragmented hard drive. Yet when I connected its HDMI output to a Samsung flat panel TV at that time, the sound didn't stutter.
So is it true that HDMI stutter is common Yamaha problem? Well I can still use optical and coaxial.
Reply 9 of 34, by Qbix
Rank DOSBox Author
DOSBox Author
Did you know that you can edit your own posts ? No need to make 3 posts in 10 minutes.
Water flows down the stream
Reply 10 of 34, by obobskivich
I wouldn't say common Yamaha problem, but common PC<->HT problem perhaps. HDMI is nowhere near as perfect as "they" would like us to believe, especially when you introduce a fully functional PC into the equation. There's no real benefit to HDMI for PCs either, especially if you don't need to spend HDCP video out/thru the receiver, as 5.1 or 7.1 lossless content on the PC is fairly rare (and it's not like DTS/Dolby lossy are "bad" in any way).
As far as the stutter - the only thing that comes to mind as potential damage would be if the Yamaha's internal relays are switching on and off with the stutter; they are mechanical parts and have a finite lifecycle, so if you have them switching a thousand times an hour you may run into problems sooner than later (e.g. instead of them lasting 30 years, they'll last 5, or something like that). But as far as blowing up amplifiers or speakers, if things aren't cranked up super-duper loud it shouldn't be fatal. That said, I wouldn't suggest leaving that situation like that long-term, if for no other reason than it's probably annoying to listen to. If S/PDIF solves the problem, go with S/PDIF.
Reply 11 of 34, by Kreshna Aryaguna Nurzaman
Indeed.
It should be noted that multichannel PCM through HDMI doesn't work for Warcraft III either. Like I said, I set nVidia HD Audio to Quadraphonic speakers, and indeed, the receiver's input channel indicators shows the receiver receives four discrete PCM channels from HDMI (L, R, SL, SR). But Warcraft III only outputs sound from the front channel. My guess is that nVidia HD Audio driver does not support DirectSound 3D.
Thankfully the relay doesn't switch with the stutter, only the receiver's input channel indicators that blinks - as well as the PCM light indicator.
I still wonder what causes the hissing sound whenever I enable surround processing for stereo analog input (the VIDEO AUX input). Oddly, the hissing gone when I choose Pure Direct mode. Anyway, the hiss become louder when I increase the volume. What's the cause of the hissing? Is that normal, or there's something needs to be fixed on the receiver?
Apart from the hissing sound, eveyrthing works fine. The receiver really looks new. Physically, my only objection is the broken front left plastic feet - probably due to the seller's lousy packaging.
I'd also like to note that this Yamaha receiver is built like a tank - reminds me of vintage amplifiers/receivers like Sansui and Marantz from the 1970s, and unlike typical HT-in-a-box receivers.
Reply 12 of 34, by obobskivich
Try other inputs, see if hiss changes.
Reply 13 of 34, by Kreshna Aryaguna Nurzaman
Tried CD and VCR, and the hissing intensity regarding to input channel is as follows (from least hiss to most hiss):
VCR => CD => VIDEO AUX
On the other hand, hissing intensity regarding to DSP method is as follows (from least hiss to most hiss):
Pure Direct (no hiss at all) => Straight Decode => "plain" Decoder/Enhancer => Cinema DSP (most hiss)
Wonder what's wrong.
There is no hiss when using DSP with digital input though, but I'm also going to put this receiver for my legacy system (Intel 440 BX with AWE32, Intel 845 PE ISA with AWE64 Gold), so the hissing is quite annoying (although, on the other hand, the hissing sound can actually give the 'retro' feel 🤣 ).
Reply 14 of 34, by obobskivich
Sounds like its either internal noise or its picking up noise from outside. Speaker sensitivity will play a role on audibility either way, most likely.
Try moving it to another location, changing cables, etc and that has no impact its likely internal - may be defect or may just be the nature of that model (and ofc different people have different tolerance/notice levels to bg noise).
Reply 15 of 34, by Kreshna Aryaguna Nurzaman
Tried it. The hissing become less severe when I swap front speakers (a pair of "bright" Kenwood) and rear speakers (more balanced Hitachi speakers), but it's still there nonetheless. 😵
Basically, it starts to be audible when I raise the master volume control above 0 dB.
Reply 16 of 34, by obobskivich
Lower sensitivity will mean less hissing - does cabling or placement make any difference?
As far as happening above 0 dB - the volume control on this thing goes from what to what? Like -70 to +30 or something like that? Anything over 0 dB and it's adding gain to the signal; usually that will also mean noise becomes audible as any noise internally ++ in signal will come through. Usually being at 0 dB is super-duper loud as well, so there's generally no need to go that high, and if it's quiet below there, I'd say it's AOK. I've never seen a receiver that doesn't put out at least some noise when put over 0 dB - think about it like "digital zoom" on a camera; it's gonna bring noise along for the ride. Some do better than others ofc, but none are perfect about it. 😊
If digital is dead silent it's likely because there's a muting relay internally (so that when the DAC is unlocked it's also muted), but in general you can also expect digital (esp optical) to be lower noise. With HDMI being wonky I'd say try another system with HDMI audio out, or try a non-computer device with HDMI out (e.g. a game console, blu-ray player, etc) and see if it doesn't run smoothly then. 😀
Reply 17 of 34, by Kreshna Aryaguna Nurzaman
Nope. 😵
Well with the current (and small) speakers, I have to pump up the volume to more than 0 dB sometimes, although there's no hiss at all when using Pure Direct mode. Maybe it's just common problem instead of particular problem with this receiver, I hope. I dunno, is there any kind of damage or defect that could cause hissing?
Reply 18 of 34, by obobskivich
Nope. 😵
Not surprising, actually. It's internal noise or noise being picked up from whatever it's plugged into - either way it's coming before the amplifier section (because it changes with volume level). 😊
How inefficient/insensitive are they? 😵
And yes - this sounds like a very typical "problem" (condition might be a better word) - going over 0 dB usually does produce audible noise to some extent. Usually with a very loud signal you shouldn't hear it though (it will be masked). No damage to speakers should be expected, and if the receiver were damaged/defective you'd almost certainly be seeing other problems.
Reply 19 of 34, by Kreshna Aryaguna Nurzaman
Nope. 😵
Indeed, and the noise increases with more complex DSP processing.
D'oh! I forgot that the laptop's Windows volume control is set to barely above minimum! So yes, I wouldn't need to set the receiver's volume control above 0 db for everyday use. Still, the fact that such hissing noise exists kinda bother me.
I hope so, but is there possibility - even slight one - that certain components have gone bad and need replacement? Nonetheless, the pure direct mode produces zero hissing noise - which shows that Yamaha receiver also works as excellent stereo amplifier.
PS: it kinda surprises me that a game as old as 1987 actually support Dolby Surround. Can't wait to test it on the Yammie - if I had an Amiga, that is. 😉
