monkey island 1 & 2
First post, by Duffman
Im wondering in Monkey island 1 & 2 (CD version) I can only get CD tracks in MI1 and midi music in MI2. Did monkey island 1/2 ever have voices in it or was it always silent when people spoke?
I do have a sounblaster 16, but since I'm running XP I'm assuming that would affect the audio.
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 1 of 11, by Dark Knight ez
no voices... not in any version of monkey island 1, not in monkey island 2.
seems to me you got the best versions out there of both of them monkey islands, so be happy already, even if they don't talk. :p
... // bda. very bda!
... // but only if you turn godo into csah.
Reply 2 of 11, by DataPro
I have the Monkey Island 1 & 2 CD Version in french (DOS).
I have an AWE64 with a genuine Roland MT-32, a Roland M-GS64 (SC88 rack version) and SoftMPU.
Monkey Island 2 works great with MIDI Music but Monkey Island freezes after the wheel code check when I use "Monkey r" parameter
With "Monkey a" parameter the game plays fine but it's adlib sound.
I also try with a disk version of french Monkey Island and it asks for an non-existing file called DISK00.LEC when I use Monkey r
I want to use it only in plain DOS mode.
With english version, I have no issue.
HP Vectra 562 P166Mhz/256Ko L2 cache/Triton 430FX - 112Mo RAM - 2x 32Go+64Go CF Card - Matrox G2 8Mo - SB AWE64 ISA (PnP) + Roland MT-32 & M-GS64 (SC-88) & JV-1010 - Nec USB 2.0 PCI - Promise Ultra100 TX2 - Hama multicard reader
Reply 3 of 11, by Roman78
Only the Remake of those two has voice. Never saw the original whit voice. Which does not means that it does not exist. 🤣
Reply 4 of 11, by DataPro
I am not looking for voice.
I just want to have MT-32 music with french language text in DOS version.
Reply 5 of 11, by skitters
DataPro wrote:
I have the Monkey Island 1 & 2 CD Version in french (DOS). I have an AWE64 with a genuine Roland MT-32, a Roland M-GS64 (SC88 ra […]
Don't you need the Roland patch for the floppy version of Monkey Island 1 as described on this archived page
https://web.archive.org/web/20130725051109/ht … e/monkey-1.html
You can get the monkeyup.exe patch from Disney now.
https://help.disney.com/articles/en_US/FAQ/Li … s?section=Games
Reply 7 of 11, by DataPro
Thanks.
I don't want to use ScummVM as I make old games working on my very old PC.
So retrocomputing only !
Reply 8 of 11, by Jorpho
I think you can display the version number of the game by pressing CTRL-V. Maybe your English version is newer than your French version?
Unfortunately beyond that I do not know how to use the French data files with the English version.
Reply 10 of 11, by zerker
Regardless if/when this thread gets moved, I had the same problem with MI1 on an MT32 with AWE64 and Celeron 500. It turns out it has stability issues with too-fast machines and MT32 sound. Try using a utility to disable the L1 cache and slow your machine way down; it should work then.
Reply 11 of 11, by DataPro
collector wrote:
DataPro wrote:
Thanks.
Then you have asked in the wrong forum. This one is for DOS games on *modern* systems.
Oh! I am sorry. I didn't realize.
Thanks for the tips. I will try.
