First post, by gamax92
- Newbie
Its an Microsoft Serial Mouse, and the left button has gone to the point where you have to force it down for it to register.
I was gonna try taking the button apart and seeing if the spring/copper plate needed to be adjusted.
Problems:
The button itself doesn't have the tab in the front of it, it has two small tabs on the side
I cannot get the board out of the mouse, since the horizontal detection part hovers over the board.
Anyone know if these are even the same type of buttons with a copper plate (and therefor if I'm wasting my time)?
They look similar to this (Different brand):
EDIT: In hopes that it helps: info on the botton:
MATSUSHITA
AH14809
14125VAC
