First post, by MrEWhite
This may go in DOS games, but why do PCI cards crash when echo's and reverb goes on in Build engine games?
Reply 1 of 6, by leileilol
Because Jim Dose` wrote some crazy assembly involving buffers and DMA in 1994, a time when there wasn't DOS-supporting PCI soundcards in the mainstream, and 486s were so they'd have to really pull out all the stops in order to get decent performance.
Reply 2 of 6, by MrEWhite
Alright, thanks.
Reply 3 of 6, by leileilol
The unforeseen consequences from heavy optimization are what cause this forum to exist 😀
Reply 4 of 6, by MrEWhite
Also, can you play multiplayer if you have the PCI patch with someone who doesnt?
Reply 5 of 6, by leileilol
It should. Modifying the sound library module should not have adverse effects on gameplay and the sync of it
Reply 6 of 6, by MrEWhite
I mean, doesn't the game check the EXE/Version?
Also would it work in Kali?
