First post, by mixael17
mixael17
Offline
Hey guys,
I am currently trying to run a program using Dosbox and I am running into the issue that says
Serial 1: Desired serial mode not supported (9600,5,n,1)
The program that I am trying to run uses 4800 baud rate, 7 bits, Even Parity, and One stop.
Does anyone know of a way to change the desired setting using Dosbox?
Thanks.
