First post, by MrEWhite
There is a black slot on the Voodoo cards, I want to know what this cable and slot does.
Reply 1 of 16, by leileilol
Hooks to the host VGA to pass your host video card through the Voodoo through to your monitor.
Reply 2 of 16, by MrEWhite
Could I hook it into a Nvidia card? Because I don't have a 2D card on me.
Reply 3 of 16, by MrEWhite
Anyone?
Reply 4 of 16, by kixs
Yes you can. Nvidia is 2D & 3D. Voodoo 1&2 are 3D only, so any 2D card is OK.
Reply 5 of 16, by MrEWhite
Alright, thanks, could I also use a higher resolution than what the card supports if I use the Nvidia card?
Reply 6 of 16, by leileilol
Resolution support is independent. Voodoo 2 mins at 512x384, maxes at 1024x768 (with SLI - without it's 800x600)
Reply 7 of 16, by MrEWhite
I'm getting a Diamond Monster 3D 4MB. What are the resolutions for it?
Reply 8 of 16, by PhilsComputerLab
512 x 384 and 640 x 480 are the main one.
The first Voodoo is quite slow in comparison to the Voodoo but it's the most compatible when it comes to the very first / old 3D games.
Reply 9 of 16, by MrEWhite
I want to know where 512 x 384 came from 🤣
Reply 10 of 16, by Davros
From the dos days
Reply 11 of 16, by leileilol
512x384 wasn't common until VESA support really gained ground and monitors became more robust (often it's a doublescanned resolution calling for 1024x768 to be supported by the monitor)
Reply 12 of 16, by PhilsComputerLab
To be honest I only use it for benchmarking 😀
Some games don't even support it, they start at 640 x 480 as the lowest.
Modern monitors and capture devices often struggle with 512 x 384 and when you have Voodoo SLI a non-60 Hz refresh rate is forced and cannot be changed. My Samsung monitor always puts up a warning, but displays it fine. But after 30 seconds it goes black so I just have to wake it up again, get the benchmark score and set it back to 640 x 480.
It's also a great resolution for CPU scaling tests.
Bur yea, nobody I think plays in this resolution if they have other options.
Reply 13 of 16, by AidanExamineer
I blame ATi. The RAGE version of MechWarrior 2 is locked to 512x384. As I recall some Xbox 360 games were slightly letterboxed so the game didn't have to render the full 720 lines.
Could be similar thinking. 340 is pretty low, 480 stresses the hardware too much, let's bump it by just a touch.
Reply 14 of 16, by PhilsComputerLab
512 x 384 was also available before 3dfx. It was definitely a in-between step on the way to 640 x 480.
The DOS version of Quake can run this resolution I believe.
Reply 15 of 16, by obobskivich
philscomputerlab wrote:
512 x 384 was also available before 3dfx. .
Well before. Old Apple computers supported/used it (like Mac II); that's as far back as I've ever tracked it. 😊
EDIT: Typo - "Mac II" not "Apple II" 🤣
Reply 16 of 16, by PhilsComputerLab
Cool, didn't know that 😀
