Voodoo 5 6000 Clone PCB
First post, by Stojke
How come no one ever cloned an Voodoo 5 6000 PCB?
I see on ebay that its possible to get an VSA100 processor for as low as 8$ per chip. It sounds pretty cool to make an PCB to fit those onto.
And i remember some people had clean 56k PCBs from when 3DFX kicked the bucket.
Reply 1 of 135, by sliderider
The complexity of the board probably plays into it. Getting 4 VSA-100 chips to play nice with each other, and having separate memory for each chip makes for a lot of extremely fine traces and redundant components. I don't think it can be done by hand.
Reply 2 of 135, by nforce4max
The problem is cost, it will cost at least several hundred dollars to make these cards and that would be bulk, even more for a small run given their complexity.
Reply 3 of 135, by G1nX
The blank pcb's you remember were not of the final revision which even that didn't work as planned. They didn't manage to mass produce 100% stable cards under FSAA so they stopped the project. It took 3 years until a former engineer created what is now known as Hank's PCI Rework which makes the Rev3400/3700/3900 run FSAA8x without system freeze.
Funny enough the Rev2600A2 didn't have this problem even thought it was an earlier design. This one's mine:
Correct. The board is very complex and that's why 3dfx took so long in creating it (they started in mid 1999) and eventually never mass produced because of the bug I mentioned.
The cost is another issue. On dedicated 3dfx forums this topic has come up before and they investigated how much it would cost for a specialized company to reverse engineer the V5 6000 pcb and they received a quote for 30k Euro or so plus 5 original cards that would be destroyed in the process as they would basically peel them layer by layer. And noboby would front that kind of money not to mentioned agree to the destruction of the original cards.
Another explored option was to ask former 3dfx head engineer now at nVidia to support this and give out the schematics to build a new one. He said the problem was that nVidia legal department wouldn't approve it since they would be using patented technology and trade marks even if they were creating outdated cards.
From a collectors point of view it's more appealing to have an original card than a replica one. For purists even modifying the cooling on "Goddess" is seen as sacrilege.
Retro-gamer & VGA Collector
Powered by Voodoo5 6000
Reply 5 of 135, by The Serpent Rider
You understand that each backer have to sacrifice hundreds, if not thousands, (dead) american presidents to get a working card? And that's assuming we won't have VSA100 chips shortage.
Reply 7 of 135, by erek
this has be done / prototyped:
https://www.modlabs.net/forum/topic/60674/
57.03 KiB
40.57 KiB
Reply 12 of 135, by The Serpent Rider
excited?
Hardly. I doubt it will go anywhere from few working prototypes. Which isn't first time happening.
Reply 13 of 135, by Tetrium
erek wrote on 2021-02-18, 01:36:
this has be done / prototyped: […]
Very impressive!
Any idea what the cost would be to produce these?
And if these can be produced in any meaningful quantity, prices for the VSA100 chips could go up relatively quickly.
My retro rigs (old topic)
Report spammers here!
Reply 14 of 135, by maxtherabbit
The Serpent Rider wrote on 2021-02-18, 02:20:
Price tag: GeForce RTX 3090 SLI.
Not that I would ever spend that much on a video card, but given the choice between the two I'd take the V5 tbh
Reply 15 of 135, by dionb
maxtherabbit wrote on 2021-02-18, 06:45:
Even as an investment that makes sense. That RTX3090 SLI will be worth a fraction of its current price in a year or two, a V5-6000 (even if it is a replica) is more likely to keep its value.
That said, I have better things to spend that kind of money on - but I can certainly feel the temptation.
Reply 17 of 135, by erek
The Serpent Rider wrote on 2021-02-18, 02:57:
excited?
would you operate one of the prototypes given the opportunity?
Reply 19 of 135, by erek
316.8 KiB
"Have a test board. Just out of curiosity tested on another PCI-PCI bridge (PI7C8140).
That project was quite easy. Only one month to complete routing. Working from the first attempt (or second). But still some testing required. Anyway, main functional is confirmed . Performance is exactly the same as on V56K. Same BIOSes, same drivers, same bugs."
