First post, by eraH_retired
Rank Retired
Retired
Hi guys,
I rewrote the wiki page for compiling DOSBox with MinGW, http://www.dosbox.com/wiki/BuildingDOSBox, mainly just compiling information from various sources into a single document.
Could you have a quick read through and see if everything looks alright?
Thanks.
Reply 1 of 2, by eraH_retired
Rank Retired
Retired
Another update on this page, I've now documented adding support for mounting OGG files in CUE images.
Attached is a shell file that you can run in msys (sh BuildDOSBox.sh) that will do all the hard work for you. It's very basic and doesn't do any checks, so make sure you have a backup of your mingw/msys environment in case something goes wrong.
* The script won't work anymore since the website that was hosting the sdl_sound diff is no longer online.
    BuildDOSBox.txt
    2.05 KiB
    98 downloads
