First post, by Milkman Dan
Hi there,
I've got following problem. When I want to install Crusader I receive this message: "Loading: [.....================================
Unable to open file (null), in file FILE\FASTFLEX.C, line 38
Frankly said, it's a small progres from version 0.60, but I'm still not able to play my favourite game. Does anybody else encounter this problem???
Thanks a lot for any clue...
Milkman Dan
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
uhr did you try changing the xms and ems options ?
As far as I know does C:NR work fine
Is your installation complete ?
Aren't you using an old configfile of dosbox ?
like this is posted somewhere:
# Crusader doesn't work without XMS (crash) With XMS it's fine
Water flows down the stream
Reply 2 of 3, by Xelasarg
Crusader - No Remorse works. Just set "EMS=false".
Thanks, DOSBox team - GREAT work !!!
    97.53 KiB
Reply 3 of 3, by suit
hi
m3h got the same problem - with or without ems
btw: i tried also win98 and dos 6.22 unter virtual pc 2004 - same error
guys i really NEED to play no remorse & no regret (and i dont want to build a pc for it (pII 333 or something)
finaly it works 😉
> config
memsize=32
xms=true
ems=false
> installed from original cd (mounted with -t cdrom from f: physical to d: dosbox) into c:\crusader (mounted my physical c drive to c:)
> put cpu cycles to 10000
now it works fine (with dosbox 0.61)
technical coordinator
rebell.at games
