problem under linux
First post, by Argh
Hello!
I've got a problem running dosbox under Mandrake Linux 9.2. Everything compiled perfectly, but when I try run the binary from the src-folder I only get the following error from the x-server:
X Error of failed request:  BadMatch (invalid parameter attributes)
Major opcode of failed request: 148 (MIT-SHM)
Minor opcode of failed request: 3 (X_ShmPutImage)
Serial number of failed request: 49
Current serial number in output stream: 50
has somebody a tip for me what has happed here? 😢
Reply 1 of 5, by falvious
try running make install and them as user type in dosbox in a console, see if that works.
i have just compiled it and installed it on fedora 1 and dosbox runs fine, just about to try a game
Reply 2 of 5, by Argh
hmm...still the same error
Reply 3 of 5, by Guest
Hmm. I see this same BadMatch when I start a freshly-compiled 0.61. Configure options don't appear to be a factor. I'm running a custom LFS distro with XFree 4.3.0.1 and SDL 1.2.6.
Guess I'm stuck with 0.60 until the problem's resolved.
(Shouldn't this thread be moved to DOSBox Development? This pertains to a potential bug, after all.)
Reply 4 of 5, by MGuppy
Hi,
I just downloaded the source and successfully compiled it (make install). Dosbox runs without a glitch (SuSE 9.0)
Reply 5 of 5, by E. Megas
(etc..)
For reference, that post was me. I've registered now.
Wanted to let you know that I ran an strace of DOSBox 0.61 on my system. Output log should be attached below. Hope it'll be of some help...
