Raven - Pentium 4 yet again
First post, by PcBytes
Back from its inactivity,my Pentium 4 goes through changes yet again.
Here are the specs this time:
ASRock P4VM800 - using Gigabyte 8VM800M-775 BIOS (a small fact all of you may find interesting : early LGA775 DDR400 boards are basically older Socket 478 boards with a new socket)
2.5GB DDR400 RAM - a rare 2GB Kingston DDR1 stick,I didn't even think there would be
Pentium 4 1.8A "Northwood" @ 2.40GHz - board originally came with a SL6PE 2.66GHz Northwood but it was dead 😢
TSSTCorp DVD Writer
400W DeluX PSU - as usual
"Human" case - a few touches in some lightly damaged parts
Western Digital WDC800JD-55MSA1 80GB - removed the 8GB drive in favor of a FAT32 pendrive which works as a HDD under MS-DOS
MSI Geforce FX5200 128MB - good card,but one question : is it DX9?
And that's all. Not listed is a RTL8139D NIC. Should mention I have to tinker with the PCI registers quite a bit since none seem to work with the Gigabyte BIOS I'm using (it's WAY easier to use than the original BIOS)
Worth mentioning,my ASRock board seems to be VERY similar to the ASUS P4V8X-MX.
Reply 1 of 20, by ODwilly
Nice score on finding the 2gb DDR stick! 1gb pieces are rare enough. As far as I know the fx5200 is dx9 capable but has sub-par gaming performance in games that utilize dx9. My next door neighbor upgraded from a Geforce4 ti4200 to a fx5600 and saw a general decrease in framerates in games but the trade off for dx9 compatibility was worthwhile to him back then. Overall an interesting change up to your p4 and 2.5gb of ram is awesome to have for xp!
Reply 2 of 20, by PcBytes
Thanks. As for the OS,I'm using Vista Home Premium, since I'm using the P4M800 chipset,which is a lot faster than the ol' 865PE P4P800-VM.
Still,need to change the BIOS' PCI registers so I can use the PCI slots.
Reply 3 of 20, by obobskivich
Very neat to see 2.5GB in such a system - 2GB DIMMs are somewhat a rarity these days. Are you planning to use this as a gaming machine? Or just a general purpose browse-the-web-and-send-email kind of box?
On the FX: The FX 5200, like all GeForce FX cards, is SM2.0a/DX9a compatible. It should support Aero if it has enough memory, at least under Vista (nVidia does not have official Windows 7/8 drivers for GeForce FX, but they do for Vista). That said, it is one of the slowest DX9 cards ever made (being the entry-level offering from the FX series). Expect performance to be in-line with a GeForce MX, but with the added PS functionality that MX lacks (which is usable in some games, albeit generally at lower resolutions). They also generally have the advantage of being passively cooled, unlike many of their FX siblings and later DX9 compatible parts.
On the boards being similar - I know that ASRock was once a subsidiary/component of Asus, so that might be a factor.
Reply 4 of 20, by PcBytes
Probably light gaming (CS 1.6,GTA San Andreas and 2005 games)is what it will be targeted to.
I don't really see them being cool at all. I have the Palit/MSI FX5200 in this PC and after a 2-3 hours of use it was hot. (I'd estimate around 55-60*C)
Of course. The P4VM800 seems to be actually a rebranded P4V8X-MX anyways.
Back to it: I've got the MSI PM8M3-V BIOS to work,however I'm facing a problem : my PCI RTL8139D NIC seems to not work correctly under Windows. It's detected,it works fine,but it shows cable unplugged,even though I have the cable plugged.
Reply 5 of 20, by obobskivich
"2005 games" may be a problem with the FX. They don't do very well with DX9 titles, especially the lower-performance models like the 5200. CS1.6 or other old titles should be no problem at all, but games like Half-Life 2, Hitman 4, etc will generally be beyond that card's reach. Something like a GeForce 6600GT would be a much better choice for DX9 titles.
55-60* C is not bad at all for a graphics card under heavy load, especially a single-slot one without a fan. Consider the 5200's big brother, the 5800 Ultra, will run 60-70* C under load (like 3DMark), with the large dual-slot blower. The 5900XT and 5700 Ultra will run similar temperatures. Some more modern cards will approach 100* C during normal operation, even with large dual or triple slot coolers (many of which make the 5800's Flow FX look tame by comparison).
With the 5200, you could put a massively over-sized cooler on it (like a VF700) and bring the temperatures down (unfortunately 5200 lacks an actual diode, so you can't measure internal temp), but it isn't necessary, and since they run passively it wouldn't benefit you (it'll just add noise, basically).
Reply 6 of 20, by cdoublejj
san andreas will play at high on an fx5200 and Athlon XP on windows 7 @1024x768 possibly 2084x1024
Reply 7 of 20, by leileilol
2084x1024? will play? fx5200? funny shit
Reply 8 of 20, by cdoublejj
iv'e got an athlon xp and Pentium 4 setup i can test with my 128mb FX5200 with, weather or not i get around to it is another story.
Reply 9 of 20, by PcBytes
Nice. Wonder if a FX5200 can run 1920x1200 though. It's a bit smaller.
Reply 10 of 20, by obobskivich
On VGA it should (it can do 2048x1536 on VGA), but on DVI it may not as the FX cards are all single-link, and some will only do 1600x1200 (vs 1920x1200). No idea if it will be playable game performance in anything at 1920x1200 or 2048x1536 etc (remember, it's not too far off from an MX 440), but for kicking out Windows desktop it should be fine.
Reply 11 of 20, by filipetolhuizen
It choked already on my old 8800GTX @ 1440x900. 😒
Reply 12 of 20, by RacoonRider
Yeah, the cooler ten times the price of the videocard. Fx5200 is a crappy card, I don't even bother keeping them. Just get over it, find yourself a nice radeon 9550 or 9600Pro, available for dirt cheap or free if you look well.
Reply 13 of 20, by Standard Def Steve
Must've been a weak CPU holding it back. San Andreas is not a very GPU intensive game. I ran it at 1920x1200 on an Athlon X2-4600 with an x1950Pro back in the day. I even had to limit the game to use just a single CPU core; it actually ran too fast on both cores!
Now GTA IV is a completely different animal.
"A little sign-in here, a touch of WiFi there..."
Reply 14 of 20, by filipetolhuizen
It was a Core2 Quad Q9650 3.0GHz. The hicups got better with a GTX 260 and went completely away with a GTX 460. The CPU stayed the same.
Reply 15 of 20, by cdoublejj
GTA 3 runs like crap, it's poorly optimized, it is the first iteration of the RenderWare engine, http://en.wikipedia.org/wiki/Grand_Theft_Auto_III
GTA VC is the second RenderWare GTA and is so optimized i can get 25-30fps on a 16mb Geforce 2 go, which is impressive when you see the system reqs,
http://en.wikipedia.org/wiki/Grand_Theft_Auto:_Vice_City
GTA SAN AN is the third iteration of RenderWare but, is also heavily modified, http://en.wikipedia.org/wiki/Grand_Theft_Auto:_San_Andreas
like wise GTA IV is the first GTA series game to use RAGE and GTA V being the second.
Reply 16 of 20, by PcBytes
Update on the P4:
Woohoo!Just found a new case for it in the dumpster. Face is a bit cracked but I think it can be fixed in the future.
It even has a backplate installed.
And obiviously,there's as much dust as there is in a unopened CRT TV. (long story short it's veeeeery dusty)
However,anybody knows the pinout of the USB header on the motherboard?
Reply 17 of 20, by nforce4max
PcBytes wrote:
Update on the P4: […]
Update on the P4:
Good that you got a better case, you can find pin outs for usb board headers online but personally if the cable from the case is in lose pins I don't bother.
Reply 18 of 20, by Tetrium
Same 🤣
My retro rigs (old topic)
Report spammers here!
Reply 19 of 20, by PcBytes
nforce4max wrote:
Update on the P4:
Just found the pinout,and it works.
Going to take some shots of the case later.
