First post, by PCG98
UPDATE- this is solved since I used the info posted here to get ATF-G running on my Win7-64 machine. I was able to use Toolkit modified files on it as well. See below for my how-to, thanks to member filipetolhuizen for his work on this.
How-to for Win7 users that find this in the future (this presumes you have installed ATF Gold and the 1.02 patch):
1. Download & install the MS Application Compatibility Toolkit. I used version 5.6, and found it here.
2. Download & unzip member filipetolhuizen's ATF.zip patch (must be registered member to download). Save to your ATF Gold directory, i.e. C:\Janes\ATF Gold.
3. Download & unzip member the Direct Draw compatibility tool (must be registered member to download). Save to your ATF Gold directory, i.e. C:\Janes\ATF Gold.
4. Run MS ACT for 32 bit OS.
a. Click on "Open" then browse to the "atf.sdb" file you unzipped. Double-click on the file and a new custom database named "atf gold" is created.
b. Right-click on the database name, click "install" and close application.
5. Run Direct draw compatibility tool.
From member filipetolhuizen: If you experience crashes between missions, tick the options Force 640x480 and 256 colours mode under the compatibility tab.
OPTIONAL- ATF Gold Toolkit
I could not get this to run in Win7-64, apparently it is a 16 bit program. It may run on 32 bit versions. I used my Win 98 machine to create my libraries and then copied them along with other sub-folders (such as "Projects") to the Win7 machine. I repeated steps 4 & 5 and ended up with a working game with my modified files.
Reply 1 of 16, by filipetolhuizen
If you can get it at least to install under Win7 x64, try my fix for it. You need MS ACT 5.x or 6.0 to be able to apply the fix.
    atf.zip
    940 Bytes
    152 downloads
Reply 3 of 16, by PCG98
Looks pretty intense/beyond my pay grade. A "quick start" guide that is 22 pages long!!!
The "step by step" is 23 pages long, and doesn't seem to cover what I'm doing. It has options for:
1) Deploying a new operating system or
2) Applying a Windows update
I "installed" your .sdb file as a database & saved it.
I re-installed ATF Gold, and then the v.2 patch.
It crashed within a few seconds.
I tried compatibility mode, Win98, and it loaded. The graphics were awful, the sound repeated when I clicked a button, and the cursor did not move uniformly.
I'm presuming I did not connect your patch to the game files. Any idea what I did wrong or need to do?
Reply 5 of 16, by filipetolhuizen
My fix has been updated to work with any version. Please try it again.
    atf.zip
    904 Bytes
    446 downloads
Reply 6 of 16, by PCG98
I see what I missed- I used the "run" function from ACT and then linked the ATF Gold exe.
That's an improvement, but the graphics are still messed up. I have them set to 1024x768 and all terrain is set to best quality. In gameplay, the sky is correct, but the land & water are funky- mostly the water.
I've attached a screen shot for the title page, it actually looks a lot better, not any black, but the quality is like it is 256 color or less.
The other pic is from gameplay, ditto the black not being there (it is proper sky), but this gives an idea of what the water looks like.
    76.55 KiB
    No downloads
    Screenshot from gameplay showing water
    18.85 KiB
    Screenshot for main screen
Reply 7 of 16, by filipetolhuizen
Then you need this as well. You just need to apply the fix once and the colour problems will be solved.
You don't need to run ATF inside ACT. Just installing the database inside should fix it everytime you run it. You'll have to disable Win98 compat. mode for the .exe too.
Reply 8 of 16, by PCG98
Thanks, that fixed the graphics, but it only works when I run it via ACT. Do I need all files in one directory, i.e. the .sdb files in the /Janes/ATF gold directory?
Any ideas on running the toolkit? It does nothing via the compatibility mode. It has a setup.exe file that must be run to install it. I may be able to copy my lib files from the Win98 machine & use them, I'll see if that works.
Reply 9 of 16, by PCG98
I figured out what I was doing wrong on running the program, I "saved" but did not "install" the custom database I created using your file. I can now run the program from the desktop. I'll read up on using ACT and see if I can apply it to the toolkit programs, both setup and run. Neither work in any compatibility mode under Win7-64.
Thanks again for your help.
EDIT
Looks like these programs are likely 16 bit. Doing some reading on getting them to work. I downloaded XP Mode and am installing it.
Reply 10 of 16, by PCG98
Success! I copied the lib files modified on my Win98 machine & was able to use them on the Win7 machine. Had to reapply everything, but once done the game worked as it should & I had my modified planes to fly.
Could not get the XP mode to load, so just as well.
EDIT
Updated/renamed original post for future users.
Reply 11 of 16, by filipetolhuizen
I don't deserve credits for DirectDraw Compatibility Tool. It was created by someone else.
Regarding ACT, you don't have to click on save, unless you modified the fix. Just click on install and it will be applied. If you experience crashes between missions, tick the options Force 640x480 and 256 colours mode under the compatibility tab.
