First post, by Guest
DOSBox 0.61
X-Wing... it says collector's edition, but the main exe is called BWING.EXE...
WindowsXP
P4 1.8Ghz
I've mounted my CDRom as both itself (E) and as D... I mounted the XWing dir, and tried running BWING.EXE directly as well as their BAT shortcut called XWINGCD.EXE (which basically runs XWINGCD2.EXE which runs BWING.EXE).
Once I get it to see the CD it'll probably tell me that I don't have enough memory.. but that's the next step anyhow.... *sighs* Does anyone have a good idea how to convince X-Wing to work?
