First post, by adslh8yp
Hi all,
Well I've got an 'old' P4 setup and wanted to try to get some dos game sound support.
As such I'm using an Ensoniq ES1370 PCI sound card (for SB emulation).
Now I am aware that the only way to get proper dos support is via an ISA based card, but this is all I have to play with right now...
I have downloaded the dos drivers from the vogons drivers page, but they simply don't work for me.
It always says 'cannot detect' or 'not found'. The IRQ/DMA etc... are correct.
Any hints on how to get this working? if at all possible (though I have read that some have gotten it working, and well the card was advertised with some dos support and came with a driver CD that had dos drivers...).
I'm running Win98SE.
Any help would be great šŸ˜€
Reply 1 of 15, by Stojke
Are you sure the card is functional? It should be detected by Windows 98 at startup, either as Multimedia Audio Device or Unknown device.
If that didn't happen, something is wrong with the card (didnt get intialised).
Try placing it in another PCI slot.
If it is detected, try manual driver installation.
Select the card from device manager and import the INI file into windows.
Reply 2 of 15, by adslh8yp
Sound works fine in windows, but not in dos (be that boot straight to dos or while within windows.
Some dos games (such as doom) work fine in WinXP with sound (though music is only general midi and the music lags, soundfx are fine though).
Reply 3 of 15, by Stojke
It seems that you are missing either the Blaster environment variable or some ES1370 specific one in your Config.sys / Autoexec.bat .
Reply 4 of 15, by adslh8yp
The driver from the vogons driver page had an included autoexec, and I used that (adjusted for irq/dma, though I did test it before I changed as well).
Reply 5 of 15, by Stojke
Try to reinstall and go trough every step manually.
Reply 6 of 15, by adslh8yp
Yeah i've spent the better half of a day on this.
Re-installing everything, same output.
Was hoping that someone who had one of these knew a trick or something.
Ready to bin the pc now 🤣.
(I'm not actually going to do that 🤣)
Reply 7 of 15, by Stojke
Yeah I know how you feel 😁
But from my experience it was usually something very simple that I missed accidentally.
Just like the time i tried to set up that Terratec Maestro 3296, I thought it was possessed, but a simple -O command in the startup solved it (override settings).
Reply 8 of 15, by jxhicks
Check your BIOS PNP settings. I remember having to turn PNP off to get this card to work properly in DOS.
Reply 9 of 15, by adslh8yp
PNP is off already (you do mean 'pnp os' right? then yes that option is off.
Reply 11 of 15, by PhilsComputerLab
I did a write up on this card a few years ago, maybe it's helpful: Ensoniq / Creative AudioPCI
All the drivers are attached.
Reply 12 of 15, by Kamerat
Thanks for the link. Found out the Creative 5507 stutter some times in DOS, so I desided to try one on my Audigy 2 ZS cards (using Audigy driver and patch) that use the same driver model. Found out that the MT-32 mapping utility from the Ensoniq driver works with the Audigy and the stuttering are also gone.
YouTube channel
Reply 15 of 15, by Kahenraz
Found it. Attaching it here.
