best directx for v3 on Win98se
First post, by dario82
please guys, what the best compatibility (for games) of directx version on win98se with voodoo3 3000?
i have try with 7.0a and last driver v3 V1.07.00 and work fine
there is a higher version of directx supported 100% my voodoo3?
Reply 1 of 20, by leileilol
You're already using it.
long live PCem
Reply 2 of 20, by dario82
mmm, ok
Reply 3 of 20, by Darkman
yes , DX7 or 8 is what I would recommend too , DX9 can cause issues with some of the older cards (for instance it caused slowdown for me, along with graphical issues in some games)
I would stick to DX7 unless youre playing a game that forces you to install DX8 (which would be a bit late for that card anyway)
Reply 4 of 20, by dario82
OK, but i have actually installed directx9c on windows98, can i uninstall dx9c with a good program? do you know the best software to use?
Reply 5 of 20, by dario82
mmm...maybe it's good reinstall windows
Reply 6 of 20, by smeezekitty
I would let it ride and if you have problems then you can try to reinstall/uninstall. Otherwise don't worry
Reply 7 of 20, by maximus
I never had any problems using DirectX 9.0c with my Voodoo3 3000. Never had problems with DirectX 9.0c on any system, for that matter.
As far as I know, the last DirectX to support Windows 98 SE was the December 2006 release (this is what I use).
PCGames9505
Reply 8 of 20, by Dreamer_of_the_past
Format and re-install is your best bet.
There is this guy at the Hardocp forum who actually went through all of these DirectX versions and he stopped at the DirectX 8.1 http://hardforum.com/showthread.php?t=1687974
Reply 9 of 20, by dario82
yes but some games not works. i have try "Requiem: Avenging Angel" not work with 9c (black screen) but it starded with 7.0a
Reply 10 of 20, by swaaye
DirectX Buster will remove DirectX for you. I use it often.
Stick with 7.0a unless you are actually playing a DirectX 8+ game. It is the most stable in my experience. You can run DirectX 7 even with newer video cards.
If you truly need DirectX 8+ you might want to run XP or Win2K.
Reply 11 of 20, by smeezekitty
I have run DX8 on several 98 rigs with zero issues. DX9 can get iffy
Reply 12 of 20, by akula65
Why be constrained by a single DirectX version? I have been using V-Com System Commander for years to create builds with multiple Win98 SE installations on the same machine, each with a different DirectX version (usually DX7-DX9). If you don't have or care for System Commander, use your favorite boot manager to achieve the same thing.
Reply 13 of 20, by dario82
in my case, best driver are dx7 for me, are more stable for my games:
screamer2,requiem,diablo2,dethcarz,motoracer,glquake,quake2,nfs2,descent2 or 3,ignition,unreal etc..
i can use in future System Commander,this looks interesting for some game with right directx
Reply 14 of 20, by swaaye
Or just use DirectX Buster, reboot, install different version, reboot.
Reply 15 of 20, by dario82
until I will be 'forced to install dx9 for a specific game, I'll keep the dx7.
i have also installed a voodoo1 card when i want play well some game for ex.screamer2 or descent2,tombraider etc... with voodoo1 primary drivers (installed after voodoo3 drivers) because i use two 3dfx cards
my question is:
Dx7 can create a conflict if i play on voodoo1 games?
Reply 16 of 20, by Dreamer_of_the_past
No such legends for you as
1. Divine Divinity
2. Dungeon Siege
3. Gothic II
4. Neverwinter Nights
5. The Elder Scrolls III: Morrowind
6. Warcraft III: Reign of Chaos
Actually most of these probably won't run well or run at all on a Voodoo3 video card.
Reply 17 of 20, by mr_bigmouth_502
Dreamer_of_the_past wrote:
No such legends for you as […]
1. Dungeon Siege
2. Gothic II
3. Neverwinter Nights
3. The Elder Scrolls III: Morrowind
4. Warcraft III: Reign of Chaos
Won't those all run fine on XP anyway?
Reply 18 of 20, by Dreamer_of_the_past
1. Dungeon Siege
2. Gothic II
Windows XP already comes with built-in DirectX 8.1, but the subject is about Windows 98 SE.
Reply 19 of 20, by AlphaWing
If I'm not running a Geforce 5 FX card, Its always 8.0 or 8.1 for me.
Never had any issues with em in 9x.
