Outcast 1.1
First post, by F2bnp
"Thank you for registering our Newsletter. You’re among the first thousand having responding positively to our subscribing request.
It’s been a while that we didn’t share about the status of Outcast's development. Now time has came to share some news with you.
I will not enter into the details of our roadmap today but one of our short term goal was to cleanup, enhance and publish the original voxel version of the game. We found that it was a required step before communicating again on the HD version or a possible follow up. Thus,we put our hand on the 15 year’s old code to build an enhanced version called “Outcast 1.1”.
Outcast 1.1 has been recompiled from the original source code. It still using the original voxel technology but it comes with following enhancements: the voxel rendering is now multithreaded for higher performance, the software meshes benefit of bilinear filtering, part of the HUD have been redesigned, skies have been painted in high-resolution, it natively supports Xbox pad, it includes a user friendly Controller configurator, it works properly on various resolutions, up to 1080p, it works in fullscreen or windowed, it features a new launcher, and a significant number of bugs fixed.
We are happy to announce that Outcast 1.1 will be also available on Steam including support of Cloud Storage,Trading Cards and Original Soundtrack DLC. If we have a positive response of the community, Stats and Achievements will be added.
Outcast 1.1 will be available Thursday 18th December at about 10am PST (8pm for Paris) on Steam, Gog and Zoom at a suggested retail price of $5.99.
We hope that this release will contribute to help us to achieve our next goal (we’ll share more on this later).
Thanks for your trust and your support "
http://store.steampowered.com/app/336610/
HOLY MOTHER OF GOD, IT'S HAPPENING! (also, free update on GoG!!!)
Reply 2 of 20, by F2bnp
Indeed! I've owned it on GoG since they first released it.
Had a go last night and they have done a pretty good job. There are some issues here and there, but I expect them to fix it and honestly they haven't annoyed me yet, just saw them mentioned.
They reworked the engine for multi-threading, but it still runs pretty slowly on higher resolutions, unless you got a fast Intel CPU I suppose.
Running at 1360x1024 on my Phenom II x6 1090T and it's hitting 60fps, so I'm happy with that. 1080p is completely out of the question, but I think 1680x1050 should be doable with a little overclocking. Hilarious that I may have to overclock to play a game from 1999 🤣 .
Reply 3 of 20, by keropi
I do get severe gfx glitches on 1920x1200 , the game is unplayable. Framerate is from 20 to 40fps on my 2600/GTX660ti pc.
The game is buggy atm, it produces some SERIOUS cpu load when it starts and my screen goes on standby mode for 1sec when it does this (wth is that? 🤣) . I am waiting for an update to really play this.
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
Reply 4 of 20, by F2bnp
Just play it on a lower resolution. You should be able to do 1680x1050 with around 60fps!
Reply 5 of 20, by F2bnp
Keropi, looks like they've updated the Steam version a few times already, fixing bugs and such.
Unfortunately, GoG is usually really slow at updating new releases. We should have the latest update come Monday.
Reply 8 of 20, by F2bnp
Yeah, quite a few fixes, although I didn't really see any performance gains like a lot of people have suggested.
Reply 9 of 20, by keropi
Just tried the patch, it's indeed better on my system but not that great.
1680x1050 is not a solid 60fps, once the scene gets complex it can drop as low as 35fps or so.
720p is almost 60fps but there are hiccups... the game really needs more optimization.
Reply 10 of 20, by F2bnp
They are trying to make it take advantage of multiple cores/threads. The original performed worse on the same resolutions if you applied a certain mod, so there is progress.
They've also greatly increased the view distance, but have disabled DoF (depth of field) entirely until they find a way to make it work properly on higher resolutions.
Reply 11 of 20, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
I just find it hilarious that such an old game gets new versions. It's something you don't see often (not counting the id software open sourcing)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 12 of 20, by F2bnp
They had a lackluster and eventually failed Kickstarter around May this year for an HD remake of the game. However, it looks like they didn't give up and are updating the game as it is, trying to show it to as many people as possible.
It's dirt cheap or just plain free if you bought the original on GoG and it's an amazing game overall 😀.
Reply 13 of 20, by bjt
Downloaded this new version from GOG, got to say it rocks.
- 16:9 and higher res support
- Sane control presets for WASD
I run multimonitor and found that I needed to switch back to a single monitor to play the game, otherwise the taskbar flashes on top of the game randomly.
My only question is, does this game perform better or worse on period-correct and retro single core machines? I'm not sure, but I don't think the software texture filtering was in the original version.
Reply 14 of 20, by F2bnp
Yeah, there wasn't any bilinear filtering in the original, I kinda prefer it that way to be honest. There's also a control scheme for XBOX controllers by default and I gotta say, it totally rocks! Certainly not a bad alternative when you want to just chill out. 😀
As for how well it works on period-correct hardware, I doubt it will run on Win98 due to dependencies on certain libraries. I'll try it on a Northwood 3.0 (actually 3120Mhz due to overclocking) in Windows XP and reply with some more details. I expect it to be fully playable at 640x480 and somewhat playable (25-30fps) at 800x600.
Reply 15 of 20, by F2bnp
Just tried it. Unfortunately, 640x480 is not completely smooth on that Northwood, although it is mostly ok. I tried 512x384 too and it still wasn't 60fps all the time. Haven't tried the original on this particular system, but it should have been running at 60fps, so they definitely managed to make the game even more demanding.
800x600 is out of the question, sub 20fps most of the time. Something that most people haven't noticed is that they removed Depth of Field in 1.1, which had a huge impact on the visuals of the original and made everything in the distance appear smoothly. Unfortunately, they said that DoF had to be reworked for higher resolutions and they're working on it and as a result things tend to pop up a lot.
I had the chance to try the original release of the game on a Pentium III 866MHz a few days ago. With everything maxed out (that means 512x384 btw 😜), the game was hovering at 30fps, which sounded about right as I had tried it years ago on a PIII 1GHz and noticed similar performance. If and when I finally build a Tualatin 1.4 machine, I'll make sure to try it out there as well and see what kind of performance I'll be getting. 😊
Reply 16 of 20, by bjt
That's a shame but not too surprising. Unfortunately it means that gog.com is no longer a good source for someone wanting to play this game on retro hardware. Luckily there are still plenty of copies in the wild.
Reply 18 of 20, by F2bnp
No no. GoG still provides the original game download as a bonus.
Reply 19 of 20, by bjt
That's fine then. They need to rename it from product_bonus_38603 😀
