First post, by Artex
I thought I'd dive into some of my Socket 3-based systems for these next few "Artex's Build of the Week" iterations. A few of these have been documented in what turned out to be a massive thread, but I know everyone loves pix so here goes!
Round three of my Socket 3 round of builds...
Memory throughput seems really low to me... not sure what's up with that. Perhaps I need to try some different memory.
Specs:
Case: Desktop AT Case with HI/LO LED Display
Power Supply: Enlight EN-825710 250W
Motherboard: Asus PVI-486SP3 (SiS 496-497) Rev. 1.2 (A4)
Cache Info:
8KB L1 Cache (In Write-back mode)
256KB L2 Cache
Processor: Intel 486 DX2-66 (80486DX266) (SX955) (Write Back Cache) (1992)
Cooling: Socket 3 Cooler
Network: 3Com 3C905B TX (PCI)
Storage:
8GB CF Card (CF->IDE Adapter) on VLB Promise Controller
GOTEK USB Floppy Emulator
Toshiba DVD-ROM SD-M1502 (48X)
Memory:
16MB RAM (2 x 8MB FPM 60ns SIMMS)
Audio:
Creative CT1690 (Sound Blaster Pro 2) (SBP2SONY) (054271) ISA (1992)
Roland MPU-IPC-T Midi Interface Card ISA & Breakout Box
Video:
Cirrus Logic CL-GD5428 CL-9028Z P104 2MB VLB
Benchmark Results:
SpeedSys Overall Score: 25.09
DOOM: 2134 gametics in 6389 realtics
Superscape: 25.5 fps
PC Player Bench: 6.0
Quake: N/A
Cache Performance:
CacheChk -d -t6
L1 (16KB) - 65.4 MB/s
L2 (256KB) - 16.6 MB/s
Main Memory Speed - 11.7 MB/s
Effective RAM Access Time (read) - 360 ns
Effective RAM Access Time (write) - 188 ns
CacheChk -d -w -t6
Main Memory Speed - 22.3 MB/s 47.0 ns/byte
Effective RAM Access Time (write) - 188ns
Onto the hardware Pr0n!
AT Case: Before and After
ROLAND!
Reply 1 of 22, by nforce4max
Nice work as always.
Reply 2 of 22, by PhilsComputerLab
That's a very fine machine! Well done 😀
Reply 3 of 22, by Robin4
The DVD drive and the floppy emulator ruins the look on this case. Never ever seen a DVD drive from years later in a 486 machine..
But the case it self looks very clean..
Reply 4 of 22, by Artex
It's more about convenience than cosmetics. 3.5" and 5.25" floppies suck. It's just easier using these drives... but I hear ya and appreciate the constructive criticism. To each his own....
Yes! The case is clean after a few hours of scrubbing! You may also ask why I'm using a VLB card in a motherboard that has PCI. To that I say..."why the hell not?!" 😀
I have several of these cards lying around. Why not use them? They aren't getting any cheaper to aquire like the masses of PCI cards out there.
Reply 5 of 22, by chinny22
Very nice, I like the Floppy emulator & DVD. Classic 486 hardware with currant useful hardware balance just right
Reply 6 of 22, by Robin4
Artex wrote:
It's more about convenience than cosmetics. 3.5" and 5.25" floppies suck. It's just easier using these drives... but I hear ya […]
It wasnt really criticism, only a opinion from my own. But i do agree with you that its more convenience.. Only it doesnt look really matching together (strange combination).
I hope i didnt hurt your feelings.
Reply 7 of 22, by Artex
Robin4 wrote:
It wasnt really criticism, only a opinion from my own. But do agree with you thats more convenience.. Only is doesnt look really right.
No harm done! I really do appreciate ALL feedback with these builds! Everyone has different tastes and I think it's fun to put my own personal 'twist' on these weekly builds. I really do enjoy it (as I'm sure everyone else does too!) 😀
Reply 8 of 22, by Robin4
Can you explain why you did choose a DVD ROM player on a 486 system? I dont think using dvds on a 486 wouldnt really make sense.. Because of the speed its running..and the technology wise.
Or was it more, because you didnt had an other one available?
Reply 9 of 22, by PhilsComputerLab
One reason might be better compatibility with CD-R and CD-RW discs? I also use DVD drives in all my systems.
Reply 10 of 22, by Robin4
Ok, thanks for the explanation.
Reply 11 of 22, by Artex
Phil's got it. Compatibility is #1. I burn a lot of re-writeable discs and these drives make it a lot easier. Otherwise it's the 1.44MB-at-a-time virtual floppies or running an ftp server after firing up mTCP. Sometimes it's quicker to burn a DVD-RW....
Reply 12 of 22, by keropi
another great build! this time it has enough Roland 🤣 🤣 🤣
Reply 13 of 22, by sunaiac
That's 8kb lvl1, not 16, on DX2s 😀
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 14 of 22, by Artex
Doh... Copy/Paste fail. Thanks!
Reply 15 of 22, by PeterLI
Cool. You should hook up a Sony CDU-31/33A to the CT1690 to really make it shine! 😀 Nice MOBO BTW.
Reply 16 of 22, by darksheer
Nice Looking build and killer Roland MPU that complete audio possibilities with the SB Pro 2 😀 , but it seems that it's running a bit slow for its specs 😕 .
Could PCI be the culprit by introducing default WS to keep system stability for RAM/CPU/VLB operations or something like that ? 😒
DooM and DooM II should be playable on a DX2 66 WB or WT with an S3 VLB card (> 25 FPS), DUKE3D should start to be playable (not really enjoyable or you have to o/c it at 80 Mhz with a 40 Mhz BUS for something smooth) by reducing screen size and audio settings.
Reply 17 of 22, by Artex
Yeah, somethings definitely off. DOOM is really choppy at full screen. Timings are tight as a drum in the BIOS. I'm going to swap memory tomorrow, and maybe try a single 60ns 16MB stick. May swap the VLB card as I'm seeing some anomalies on-screen during gaming {vertical banding}.
Reply 18 of 22, by feipoa
A 486 can burn DVD's with the appropriate hardware and software. 486 DVD burner
A 486 can playback DVD movies with the appropriate hardware and software. MPEG 1/2(DVD) hardware decoder cards
A DVD burner in a 486 could serve as a backup means if one so chooses this method. A DVD reader could also be used to read data discs for system restoration.
Reply 19 of 22, by Skyscraper
Nice build 😀
I do also prefer DVD-RW drives for the same reason.
DVD-RW drives are also (often) better when it comes to reading scratched discs.
