First post, by alivemanslayer
I can't open the key mapper, go to full screen, or use any of my special keys. Are there commands I could type in that do these functions? Otherwise I'm stuck playing in a tiny window.
Dosbox? Please more information...
Yes Dosbox.
alt+enter does not work nor does ctrl+1 nor ctrl+4. I just started using dosbox and I can't figure out what's wrong. I tried reinstalling it, but that didn't work.
Now I wonder if there is a command I can enter to open the key bindings or make it full screen just like I can change the cycles
Which OS what kind of computer? Multimedia keyboard?
I am running windows 8.1 on an HP laptop and I have a Logitech k120 keyboard. It doesn't work on the Logitech nor the laptop's keybord
HP laptops.. Those often have a broken keyboard driver installed
Right-Shift / Backslash Keyboard Problems (SOLVED!)
Water flows down the stream
