First post, by PcBytes
Been a lot since I've built something that works so I thought I'd post it here:
MB - ASUS A7N8X-E Deluxe 😎 - put an ECS heatsink on the SB 🤣
CPU - AMD Duron 1300MHz - got a Athlon XP 1900+ but saving it for the Retro Rig v1.4 (nF2 based like this one)
Memory - 1.50GB DDR400 RAM - double sided chips! 😈
GPU - Radeon HD3450 512MB - need it for GTA San Andreas (I'm sure it runs) - sits in a AGP Pro slot 😁
HDD - WDC WD800JD-55MSA1 80GB SATA - using it through Silicon Image controller onboard
LAN - Dual LAN onboard! (Realtek and nVidia)
TV Tuner - Winfast TV2000XP Deluxe
OS - thinking of Windows Vista SP2,just because fancy motherboard needs fancy OS 🤣
HSF - Titan TTC-D9TB/CU35/R1,replaced the fan with a 80mm Delta fan (and it's a quiet Delta)
DVD-ROM - Lite-On LTD-166S
PSU - Rexpower PX-400 400W PSU (recapped)
Reply 1 of 7, by RacoonRider
Why would you run Vista on Duron 1300? Why would you run Duron 1300 anyway? It's way older then everything else in your system.
Reply 2 of 7, by nforce4max
I tried it on a 500 mhz P3 BX rig back in 2007, it worked ok aside from the fact I was using a Riva TNT for a graphics card. OP should using 98 or XP instead.
Reply 3 of 7, by PcBytes
One reason I've been turning for Vista SP2 is because it has updates and supports. And BTW,I've seen some Duron/Athlon XP systems run Windows Vista. (iirc around 2007/8 or so)
The Duron 1300 is the only CPU I've got it to post with. I have a Sempron 2400+ and a Athlon XP 3200+ but neither POST. The Sempron 2400+ wouldn't POST (yet it would POST on a ECS K7S6A)by giving a black screen,and the Athlon XP 3200+ turns on for about 1.5 - 2 seconds and shuts off. The Sempron 2400+ seems fine,however the AXP 3200+ seems to have some very light brown on the underside center. I also have a 2200+ though,but I didn't test it yet.
Oh,and does anybody know how can I make the motherboard talk? It has a speech option in the BIOS,yet it doesn't do anything when enabled.
Reply 4 of 7, by RacoonRider
I would not care about the updates if I were you. My Athlon 3200+ runs XP SP2 and I even surf the net with it from time to time. It's not like you have any crucial data there, why bother?
Reply 5 of 7, by PcBytes
No crucial data in there right now,but I will save some in the future. Plus it's my backup machine. Right now I need the SIL3112 drivers to reinstall Windows.
Reply 6 of 7, by PcBytes
Just finished building it back. Replaced the Rexpower PSU with a SumVision KY-450ATX that I've recapped today.
Also,here's another one:
MSI K7N2 Delta-L
1GB RAM
Athlon XP 1900+ 1.2GHz
Rexpower PX-400 PSU (better than the gutless wonder it came with)
Lite-on DVD-ROM
20GB HDD
no OS
FX5500 256MB - passive heatsink
C-Media 8738 PCI audio
D-Bracket
RTL8139 NIC / nVidia nForce NIC onboard)
This one doesn't POST though,need to check what's wrong with it.
Reply 7 of 7, by PcBytes
PcBytes wrote:
Just finished building it back. Replaced the Rexpower PSU with a SumVision KY-450ATX that I've recapped today. […]
MSI K7N2 Delta-L
1GB RAM
Lite-on DVD-ROM
20GB HDD
no OS
D-Bracket
Just fixed it. The problem was the FX5500 being dead (it worked until that point),so I replaced it with a MSI Geforce FX5200 w/TV out and now it works.
Though,it seems it doesn't like 166MHz FSB jumper setting.
