First post, by meljor
Did a lot of benchmarking in 3dmark99max, just to see which cards run best on a low end p3. Will add K6-2 450mhz later when i'm done with that one.
It is 3dmark so games will probably act different but atleast it's something. Tested only in 16bit color so i could compare 3dfx cards.
Clocked the p3-450 @ 300mhz and 450mhz and tested in 800x600 and 1024x768. 3dmark99max supports the SSE feature of the p3 so a p2 cpu will be scoring lower i think.
Matrox g400 didn't get a score for 1024x768 with the p3@450mhz. The fps counter got stuck everytime at strange values so i didn't include the score. Probably a driver problem or something, the card ran very well in the other tests and is surprisingly the fastest!
Ofcourse on this platform Geforce2ti and higher will give you free AA/AF as they are pretty cpu bound.
Notice the VERY poor scaling of the fx cards.......
Enjoy, hope it is useful for some (i enjoyed doing it anyway) 😎 Sorry for the somewhat sloppy charts, it was the first time i ever used excel 🤣
Drivers used:
Ttnt to geforce 4 ti4200 driver 40.71
Fx cards: driver 71.84 (didn't realize 40.71 wouldn't support FX series)
3Dfx cards: V1 to v4 Latest reference drivers
v5 amigamerlin 2.9
    1.43 MiB
Reply 1 of 45, by JayCeeBee64
Rank Retired
Retired
Interesting results meljor, thanks for doing this. I recently got myself a P3B-F with a P3-600 Katmai and was wondering which AGP card to use from my collection; the charts you made are very helpful in planning my future build. Cheers 😀
Ooohh, the pain......
Reply 2 of 45, by meljor
Thank you. The question pops up every now and then so i thought let's test it.
Reply 4 of 45, by jwt27
Nice benchmark, great work!
Odd though how your Voodoo3 PCI and Voodoo4 AGP achieve similar scores. I found the V3 PCI to be painfully slow compared to a V3 AGP.
Reply 5 of 45, by brostenen
Just my question too. Why not tested a TNT2 Ultra?
I do have an G400 Dualhead AGP, and if it's better than the TNT2 Ultra in my P3-500, then it's going to replace it.
I think that the G400 somehow is more capable than some people are giving it credit for.
Shure is cheaper than getting one of those Voodoo PCI Cards. Hmmmm. Wonder why! 😁
Great job none the less. Good work and thumbs up.
Reply 6 of 45, by meljor
RacoonRider wrote:
Funny how m64 gets worse results than TNT1 😀 Do you have a normal TNT2 to try?
I don't! still looking for an ultra card. I have other cards but i couldn't be bothered as they wouldn't paint a different picture or are build in systems. Only interesting ones would be the 6800ultra and v5 5500 agp version but i didn't want to take them out of their home 🤣
Reply 7 of 45, by meljor
I think the v4 needs a little bit more cpu power to make a difference, but it isn't a very fast card. At current 3dfx prices the 3000/3500 are the best choice.
A while back i tested some cards on my p3-1400. In 3dmark99 (only tested 800x600) the 2000 pci scored 6049, the 3000 agp 6784, the v3 3500 did 7486 and i didn't have the 4500 back then but i simulated with v5 agp with one chip off: 8181 3dmarks
In the p3-1400 the 2000 pci was 5% faster than the agp 2000, it could be that i tested (in both cases) the sgram version which seems to be quicker. Have to check that and will test both sd- and sgram cards on the k6-2 benchmarks i'm running now.
Since the ti4200 has no external power i'm a little scared of frying the ss7 board so i might keep this one out of the tests on this platform, any comments on that?
Reply 8 of 45, by sliderider
Not so funny when you consider the M64 has a 64-bit memory bus while the original TNT is 128-bit. The M64 core might be clocked slightly higher, but not enough to make up for the throttling that the memory bus inflicts on it.
On paper, the performance of the core of the M64 is identical to the core of 128-bit TNT2, because it's the same core, but it's when it tries moving information over the memory bus that it falls down.
http://en.wikipedia.org/wiki/List_of_Nvidia_g … its#Pre-GeForce
You'll notice the fill rates are higher for the M64, but in reality it never achieves those speeds. The original TNT can go flat out at it's maximum rated speed without being hamstrung by memory bandwith constraints. The early GeForces were similarly hamstrung by a poor memory architecture that couldn't keep up with the demands of the core.
Reply 9 of 45, by meljor
wow.... started benching on a ms-5169 ali V ss7 board and it is giving me a VERY hard Nvidia time.
Was almost done with the voodoo's and matrox cards which were running as expected but hit the first bump with TNT1. After some driver switching i got it running fine. So in went the tnt2 m64... i tried 2 of these and they completely destroyed agp support 😐
Got it up and running again and tried gf2mx and gf4 mx440 and again lockup after lockup 😵 Now even 3dmark wouldn't start anymore.
Got a few more things to try but i'm afraid i have to swich to a p5a board and do it all again. It will probably give me troubles with one of the cards but it should work with most of them.
Reply 10 of 45, by Stermy57
Woow well done man! 😀
I did something like that some months ago with a Pentium 3 700mhz coppermine + Msi 370 VIA with some old GPU
I have two TNT2 Ultra if you want, I can do some benchmarks 😉
Reply 12 of 45, by falloutboy
This registry settings should help with Nvidia cards 😎
[HKEY_LOCAL_MACHINE\Software\ALi\ALi AGP Driver]
"AGPDataRate"="1"
"ForceSBADisable"="0"
"ForceAGPEnable"="1"
"FrameBufferSize"="C"
"FrameBufferDisable"="0"
"GATMode"="0"
"K6SetEWBEC"="2"
"UseUCForWC"="0"
"GTLBAlwaysFetch"="0"
"ResetAGPCommand"="0"
"MaxPCIRetryCounter"="0"
"AGPTiming"="0"
"PCIMode"="0"
"ForceAssertRequest"="0"
"DisablePCIReadPrefetch"="0"
"AGPDelayClock"=hex:10
"SDRAMDelayClock"=hex:10
"K6WriteAllocate"="2"
"PADInputLevel"="1"
Reply 14 of 45, by Stermy57
falloutboy wrote:
This registry settings should help with Nvidia cards :cool: […]
"AGPDataRate"="1"
"GATMode"="0"
"K6SetEWBEC"="2"
"UseUCForWC"="0"
"AGPTiming"="0"
"PCIMode"="0"
"PADInputLevel"="1"
I will try! Thanks for sharing
I have done some tests last summer and it's better to use old detonator version like 10.X or 6.X
Reply 15 of 45, by Putas
sliderider wrote:
In reality no bottleneck is absolute. There is more to it than fillrate:bandwidth ratio. When using resolutions in which these cards usually deliver smooth framerates, the m64 often wins.
I would be also careful to call memory architecture of early GeForces poor. Yeah it was the weak point, but with exception of Kyros there weren't chips with better overall efficiency in that generation. It got the job done.
Reply 16 of 45, by swaaye
Do you consider Radeon to be outside of the early GeForce generation or not sufficiently more efficient?
Reply 18 of 45, by swaaye
Putas wrote:
definitely not sufficiently more efficient
bigger die, feature parity, less performance
Interesting. I didn't know Radeon was the larger chip. I wonder if most of that is caused by the additional efficiency improving hardware.
Reply 19 of 45, by meljor
By changing 2 registry settings i got the cards working on the msi board. Got all the data up to the geforce4 ti (it worked fine but i wouldn't trust it long term as it takes a lot of power from the agp slot).
I included a v3 3500tv and matrox g450, excluded FX cards as they really refused to work on this board.
Coming week i will make the chart.
