First post, by 386SX
Hi all,
I've got this K6 III 400 on the Chaintech 5AGM2 mainboard. This mobo would need a special usb connector to enable the onboard option of the Via MVP3 chipset so I choosed to use a Via based 4-1 USB2 pci card.
The problem is that no matter I install it with default or via drivers, it crash the system at boot at Windows logo. I also used a different NEC based usb card and it just crash at the same time. I read somewhere that VIA MVP3 had problems with AGP <-> USB but I don't understand what kind of conflict is there. I tried different configurations of vga and audio card but nothing solve it.
Any advices?
Thank
Reply 1 of 6, by alexanrs
Have you tried different slots? Enabling or disabling PCI bus mastering? Also try removing other PCI devices for testing purposes.
Reply 2 of 6, by 386SX
Yeah I tried but the pci bus mastering is not in the bios options and to enable it on windows I should at least boot into normal mode with some tool. Strange to me that even another functional different chip based usb card crash in the same way.
Definitely a tough experience this mainboard....
Reply 3 of 6, by luckybob
disable EVERYTHING you can in the bios. parallel, serial, 2nd ide slot (if possible).
Reply 4 of 6, by 386SX
Already done.. 😁
Reply 5 of 6, by Jorpho
I had an unreliable card once that behaved in very strange ways. Do you have anything plugged into the USB card? Have you been able to use the card on a different system? Have you tried booting Puppy Linux from a Live CD?
ETA:
Is this Windows 95, 98, or what? Windows 95 was never particularly compatible with USB.
Also, have you disabled the onboard USB in the BIOS?
Reply 6 of 6, by swaaye
I've had problems with VIA USB 2.0 cards. I think it's a PCI revision issue. The NEC based cards are usually more compatible with pre-2000 motherboards. Just search the forum a bit and you'll find some threads from the past.
