DECpc 486 to the limits
First post, by 386SX
Hi all,
just the satisfaction to say I actually found (finally) an Intel Overdrive 100 (5v) for this 486sx (originally 25) motherboard of an old Decpc. I already tested it with an Overdrive 66Mhz but today I got this 100Mhz (read 95 actually 33x3) and it runs incredibly well! And I found also a pair of 16Mb 72pin that incredibly this mainboard can read (only 4 of other maybe 30 simms I tested are read correctly) for a total of 64Mb.
I have to find the cache memories this will be difficult.
So Decpc 486 mainboard with ODPR 100 (33x3), 64Mb, 512Mb Seagate with an AT supply into an ATX modded case! 😁
I am going to test it with some tools and games so I hope to update with some results.
Actually posting with it with Offbyone browser!
I'd like to use this Trascend 512Mb Flash ide module I don't have the supply cable for that connector, where could I find one or adapt it?
Thank
Reply 1 of 6, by luckybob
pictures of module would help
Reply 2 of 6, by i486_inside
386SX wrote:
Hi all, […]
Hi all,
Thank
It sounds like you are looking for a cable like this
http://www.ebay.com/itm/Transcend-Disk-On-Mod … =item43cc7f917b
Reply 3 of 6, by 386SX
Sorry I forgot to post the connector image but it looks like that in the auction. What i dont understand if it is a proprietary connector or not. Sure it's impossible to build one.
Reply 4 of 6, by luckybob
its standard connector for DOM modules. they are actually so common for server boards the motherboard itself will supply power. That said, one pin is ground (black) and the other will be 5v. (red). The one in the auction converts a "normal" disk drive connector to that of the DOM.
Reply 5 of 6, by 386SX
Thanks! I'm going to search one cause I would like a bit more speed on the disk side.
Anyway I don't have many numbers for now but compared to he 66Mhz with 36Mb, Windows 95 is actually faster, not that much I was obviously expecting and not even close to the P75. Quake at full screen 320x200 is playable as I remember from the minimun requirements but really pushed to its limits. I would say from 10fps to 20fps.
Reply 6 of 6, by 386SX
Some bench:
System Speed Test Ver 4.70
CPU is in V86 mode: No
Processor : Intel 486DX4(tm) 100 MHz
CPUID (TFMS) : 0480 Codename: P24C (0.60um)
Feature : MMX(tm):No, IA SSE:No, IA SSE2:No
CPU speed index : 38.72
Total memory size : 64 MB
Memory speed index: 46.88
VESA OEM String : S3 Incorporated. 86C801/805
VESA video memory : 1024 KB (4092 KB/s)
Hard drive 0
Model (PM): ST5540
Tested in FAST mode
Maximal seek time : 5.67 ms
Average seek time : 4.91 ms
Track-to-track seek : 3.23 ms
Random access time : 12.25 ms
Linear verify speed : 4214 KB/s
Linear read speed : 1975 KB/s
Buffered read speed : 2017 KB/s
Hard Drive speed index : 119.26
ATA/ATAPI Device Information
IDEMaster ATA ST5540
³ Cylinders: 1050, Heads: 16, Sectors: 63 (516 MB)
³ Maximum Transfer Mode : PIO 4, DMA 2
³ Cache Buffer Size : 256 KB
Cache/Memory Benchmark
³ Read ³ Write ³ Move ³ Average ³
³ Cache Level 1 ³ 92.50 MB/s³ 40.59 MB/s³ 39.85 MB/s³ 57.64 MB/s³
³ Memory ³ 27.34 MB/s³ 40.59 MB/s³ 19.45 MB/s³ 29.13 MB/s³
WinTune 98
Offline Test Results
CPU (1) Intel 486DX4@100 MHz
Video Board S3
Video Mode 1024x768@8bits/pixel
RAM 64 MB
OS Windows 95
Area Tested Value
CPU Integer 76,25449 MIPS
CPU Floating Point 40,98196 MFLOPS
Video(2D) 8,745406 MPixels/s
Direct3D 3,698057 MPixels/s
OpenGL 1,024292 MPixels/s
Memory 42,7346 MB/s
Cached Disk 4,916044 MB/s
Uncached Disk 0,7123531 MB/s
SisoftSandra 99
CPU Benchmark Drystone: 92 MIPS
CPU Benchmark FPU: 37 MFLOPS
CPU Multimedia Integer ALU: 69 it/s FPU: 28 it/s
Memory benchmark: CPU/Memory: 23 MB/s FPU/Memory: 22 MB/s
next HwInfo dos tests...
What do you think, it's ok for this configuration?
