First post, by F2bnp
 - l33t
We've all been there. Built a system that has no need of a floppy drive, turned the floppy drive controller off and every similar option. And yet the phantom floppy drive still exists! I've seen it under Win98 and WinME, classified as a removable drive.
Under Control Panel/System/Performance, the following always appears "Drive A is using MS-DOS compatibility mode file system".
It is more of a nuisance than an actual problem, but has anyone ever managed to get rid of this? As far as I can tell it ain't doing anything harmful, other than driving me semi-nuts 😜.
