First post, by superfury
Anyone knows what the effect of this bit is during memory reads/writes?
O/E Page -- Odd/Even Page Select "Selects the upper/lower 64K page of memory when the system is in an eve/odd mode (modes 0,1,2, […]
"Selects the upper/lower 64K page of memory when the system is in an eve/odd mode (modes 0,1,2,3,7).
= 0 selects the low page
= 1 selects the high page"
Does this simply enable/disable the copy of the low 2 planes (0/1) into the high 2 planes (2/3) during memory reads/writes?
Like:
planes = 3; //Planes 0, 1 or both set, depending on memory address! Write to planes 0&1 in this example.
if (MISCOUTPUTREGISTER.OE_Page)
planes |= (planes<<2); //Copy to the high planes too!
//Perform writes to planes 0, 1, 2, 3 depending on bits 0, 1, 2, 3 in planes.
Or is it simply:
//offset=CPU offset requested.
planes = 1; //We're a to access to the first or second plane!
useoffset = offset; //The offset requested by the CPU!
useoffset &= ~1; //Clear bit 0: we don't use it for address calculations!
if (offset&1) //High plane requested?
if (MISCOUTPUTREGISTER.OE_Page) //Use high page?
planes <<= 1; //Take the high 64k offset! So plane 1/3! The offset is used as a word mode during rendering!
else //Use low page, but odd offsets?
useoffset |= 1; //High byte within the low plane! So plane 0/2@(offset+1) (like mode 6h)
planes |= (planes<<2); //Take high planes too!
Is this correct? Anyone knows the effect of this bit on memory reads&writes by the CPU? What happens when it's toggled on and off?
Anyone can tell me more about the effect of this bit?
UniPCemu Git repository
