First post, by QBiN
 - Oldbie
There have been threads past and present discussing the -5V line present on ATX power supplies (ATX v1.2 and prior) and missing in later versions of the ATX spec. Newer power supplies lack a -5V which can cause much problems and failures for fans of retro systems. I was hoping to start this thread to document which ISA cards and other peripherals need -5V and the symptoms experienced when -5V is not available. I'm by no means the expert, but thought Vogons a great place for people to contribute what they know towards a comprehensive list. That's is something anyone looking to to build a retro system could benefit from.
ISA Cards:
- Creative Labs CT-192x - AWE32 Upgrade ISA Card (aka "Goldfinch") - Symptom: Low / No Audio
 - Creative Labs CT-1350B (Rev 049151) - Sound Blaster 2.0 - Symptom: Low / No Audio
 - Roland LAPC-I - LA Synthesizer + MPU-401 Card - Symptom: No Audio from LA Part
 - Media Vision PAS16 - Pro Audio Spectrum 16 (650-0044 56B / FCC ID: IXW-PAS16NS) - Symptom: Incorrect Playback Speed / Timing Circuit Issues
 - Media Vision JAZZ16 - Jazz 16 (650-0066-02 / FCC ID: IXW-JAZZ16) - Symptom: Incorrect Playback Speed / Timing Circuit Issues
 - Media Vision Pro Audio Studio 16 - PAS Studio 16 (650-0052) - Symptom: Incorrect Playback Speed / Timing Circuit Issues
 - 3Com EL16/TP - Etherlink 16 TP, 16bit NIC - Symptom: ??
Let's keep the list going... I'll edit and update this post with any information that comes in the replies.
EDIT 23/03/2015: Added SB 2.0 Rev.4 and 3Com EL16/TP
EDIT 23/03/2015: Updated LAPC-I entry
EDIT 23/03/2015: Added/Updated MV PAS entries
