First post, by Sammy
I installed win95 and win98 se under Dosbox to test Need For Speed SE..
I can install and start the game, but when i start a race in normal mode the game crashed after a few seconds of driving.
In 3dfx mode it crashes right after when i see the other cars and racetrack (before the 3,2,1 go! )
In 3dfx mode even the Menu has Graphic errors.
Dosbox crash not, only the Game crashes me back to my virtual win95/98 Desktop.
When i set sbtype=none in Dosbox.conf then i can play with no Problems in Normal and 3dfx mode..
And the menu of the 3dfx version then works with no problems.
Is there a conflict with sb16 and other hardware ?
Reply 1 of 3, by vytra
I can install and start the game, but when i start a race in normal mode the game crashed after a few seconds of driving ?
- from win95/win98 Need for Speed You can run directly.
p.s.
.. in common case, I sugest use XP.
