First post, by MabusRaeen
I'm planning on building a new frontend for DosBox.
I have a few ideas on how to do this. But I could always use some input.
First, some things that I am planning.
- EVERYTHING that DosBox offers as a configuraton option will be available through the GUI of the frontend. By setting defaults you can make your life a lot easier.
- A per game profile which is build using a wizard. EVERYTHING that DosBox offers as a configuration option is manageble per game with this wizard. However, by configuring default options you can click through the wizard quite fast. In an ideal situation you only have to enter something in 3 screens.
- The ability to start games using the frontend (doh)
However I'm thinking about doing this a little different. I'm planning on having the frontend close (to save resources) at game launch and open when you close dosbox.
- Exporting a game profile.
When you have a working configuration why not share it?
- The ability of creating a shortcut of a gameprofile on your desktop.
Saves you the trouble of having to boot to frontend.
- The frontend will be properly documented with a help file (chm)
- The frontend will be distributed with a setup program.
- It won't cost you a dime.
If anyone has any good idea's. Please, do share.
Input please!
