First post, by dr.mdr
debug:
85155723: DOSMISC:Call is made for list of lists - let's hope for the best85156047: FCB:DOS:29:FCB Parse Filename, result:al=085156058: FCB:DOS:29:FCB Parse Filename, result:al=085156130: EXEC:Execute C:\dos4gw.exe 385156130: FILES:file open command 0 file C:\dos4gw.exe85157689: FILES:file open command 0 file C:\DOS4GW.EXE85157902: FILES:file open command 0 file C:\DOS4GW.ETX85158795: BIOS:INT15:Unknown call BFDE85158850: DOSMISC:DOS:Multiplex Unhandled call 168785158873: BIOS:INT15:Unknown call BFDEDOSBox switched to max cycles, because of the setting: cycles=auto. If the gameruns too fast try a fixed cycles amount in DOSBox's options.85162548: BIOS:INT15:Unknown call BF0185162548: BIOS:INT15:Function 0x88 Remaining 0000 kbAbort (core dumped)purepig@:~ %adc [bx+si],al ds:[0000]=10600000:000F F060 lock pusha0000:0011 1000 adc [bx+si],al ds:[0000]=1060(Running)
this game is ok ,under gentoo + dosbox
but not work , under freebsd + dosbox
anyone help me!
