First post, by Artex
- l33t
Hey guys-
Anyone know if there is a repository of IBM Aptiva BIOS files anywhere? I restored an IBM Aptiva E 590 (2174-590) with an Anigma S30 Slot A motherboard. The system is from 1999 and the BIOS shows S30EN0V and has a date of 09/07/99. Just curious if there is something newer out there, but so far I've not been able to find any BIOS files for this model.
It's acting flaky (locking up, random beeping - 2 short beeps then 9 more short beeps) and I may just swap the board with an Asus K7V (Via Chipset), and replace the 550Mhz K7 with an 850Mhz K7 (also an Athlon "Classic") that I picked up for cheap along with a Slot A Golden Orb. The Aptiva post screen drives me nuts too - can't see what's going on!
Here's the info I have on the board itself..
IBM APTIVA 2174 AMD Motherboard 19K3399 ANIGMA S30
Processor/Speed AMD Athlon(TM) 550MHz-950Mhz 3D+
System board chipset AMD Irongate/Viper (750/751)
System board form factor ATX
Front-side bus speed 200 MHz
(100MHz double clocked DDR)
Slots (ISA/PCI/shared) 0/5/0
AGP AGP 2X slot
Memory PC100 SDRAM DIMM
Std/Max (MB) 64MB/768MB
Sockets (Total/Open) 3/2
