First post, by comteck123
I need help running TS on dosbox but i want to replace dos4g with dos32a but it wont work. Tried sb /b /r skynetw.exe and sb /r skynet.exe but it wont work. Shows me this after crashing:
    8.28 KiB
The Shadow Warrior Mod that makes weapons O.P., plus adds more ammo: My First Shadow Warrior mod.
Reply 1 of 19, by Jorpho
Maybe there's something in the executable that checks whether it has been modified?
I think you can run the game with DOS32a just by typing "dos32a skynetw.exe" without using sb.
Reply 2 of 19, by comteck123
Nope. Still crashes but this time Dosbox did fully crash. Also I am doing this because when I load the save game for like multiple times it just crashes and says DYNX86 can't run code in this page.
Reply 3 of 19, by collector
DOSBox questions should be asked in the DOSBox forum. Perhaps a mod would be so kind as to move this for you.
Reply 5 of 19, by Jorpho
And the same thing happens when you don't use DOS32a?
Anyway, using core=normal in your dosbox.conf might be worth a try.
Reply 6 of 19, by Silanda
I've just tried this game with dos32a in 0.74 and a current SVN build. The results were strange. At first it worked, then it crashed out repeatedly with integer divide by zero errors, then I reinstalled it and it worked again. I'm slightly perplexed.
One question though: what version of the game are you running? 1.00 or 1.01? The version on my cd is 1.01 and it doesn't come with a skynetw.exe.
Reply 7 of 19, by comteck123
I am running v1.01 and he skynetw.exe is just a backup.
Reply 9 of 19, by comteck123
It runs but crashes when I load a save game multiple times. With an error saying: DYNX86: cannot run code in this page.
Reply 10 of 19, by Jorpho
"DYNX86: cannot run code in this page" implies a problem with the dynamic core. That is why I suggested using core=normal in your dosbox.conf . Have you tried that yet?
Reply 11 of 19, by comteck123
I tried it and after a few loads I get this:
    3.79 KiB
    I always get this everytime.
Reply 13 of 19, by Jorpho
You say it happens "after a few loads" but your caption says "I always get this everytime", so which is it?
Also, does that happen with both dos4gw and dos32a?
Reply 15 of 19, by comteck123
I always get that everytime I load my save game a few times. And it happens in both Dos4gw and dos32a but with the latter, it immediately crashes after I reload my save.
Reply 16 of 19, by Jorpho
Qbix wrote:
Isn't skynet known for its instability ?
Yes indeedy.
Skynet (crash when re-entering buildings)
Terminator Future Shock issue
Someone posted a patched EXE here once:
Terminator Skynet problem
Reply 17 of 19, by comteck123
Well, it seems that months later I finally figured out the problem. Apparently It crashes when the cycles are set to auto but after setting it to fixed 60k cycles it doesn't crash anymore.....for now! BTW I used the patched exe.
Reply 18 of 19, by OokOok
The referenced patched executable didn't do anything for me, but what did work was to strip the embedded DOS/4GW (using DOS/32A's "sb" tool) and then run the game through DOS/4GW 2.01. It's been completely crash-free after that, even inside the toxic plant in Future Shock, which crashed every five seconds otherwise.
Reply 19 of 19, by comteck123
Also I can play the game crash free using the emucr.com svn builds of dosbox. Just make sure you have fixed cycles around 60k or it will not work
