Unisys CWD 486DX2 66mhz
First post, by kin
Finally got this nice little unit. 😊
Maybe replace the HD with a CFcard.
CPU maybe upgrade to DX4 100mhz or even an AM5x86 133mhz, though need to cut a hole in the slideable rack
on the right of floppydrive to make some clearance for the cpu coolblock/fan + drilling holes in the casing above that area.
So far, I have tried many games like transport tycoon deluxe, doom, little big adventure...etc. and all works well except Duke3D which is
just playable in 320x200. Transport tycoon seem to be slightly stuttering but I think it's bacause of the harddrive.
Needed to modify the case in order to fit a sbpro2 card.
The jumper on my sbpro2 card is set to IRQ7 in order to detect the card (IRQ5 didn't work).
    78.87 KiB
    65.9 KiB
    101.49 KiB
    71.77 KiB
    84.84 KiB
Reply 1 of 28, by Skyscraper
That seems to be a nice system!
If you decide to upgrade be sure to get a 5V DX4 CPU or a DX5/586 "upgrade kit" where the CPU has its own power converter because I do not think your board supports 3.3V.
Check what voltage the CPU you have now run at first in any case because there are AMD 3.3V DX2-66 CPUs, but most DX2-66 CPUs run at 5V.
Reply 2 of 28, by PhilsComputerLab
I had this machine with a Intel DX4 chip. I regret selling it, it was such a lovely machine.
The space for an ISA card is quite short. I'm pretty sure I had a Sound Blaster AWE64 in there.
Not sure what the hard drive size was, but I used a parallel port ZIP 100 drive to install Windows 95. That machine went in my suitcase and was used in a few countries. Locally I just got a cheap CRT and I was set. I remember how slow the Internet was, but typing assignments in Word was actually working quite well.
I was always worried about that PSU with the tiny fan. But I never had any issues. Great little machine.
YouTube, Facebook, Website
Reply 3 of 28, by kin
The CPU is covered with a sticker or paste and on top the starshaped heatsink.
So I use chkcpu and it appears to be:
GenuineIntel 486DX2 C-Step
Reply 4 of 28, by Skyscraper
That is a 5V CPU. All Intel 486 CPUs are 5V if Im not mistaken.
An Intel DX4 100 should work or for example the rather common Kingston (AMD) 586-133 upgrade CPU for 5V systems.
Reply 5 of 28, by sunaiac
Intel's DX4s are 3.3V
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 6 of 28, by PhilsComputerLab
Yup. It needs to be the Intel DX4 OverDrive, which is compatible with 5V. It looks a bit different, with writing on the cooler and some electrical components for converting the voltage.
Reply 7 of 28, by Skyscraper
You are both correct.
I do not have any iDX4 CPUs but it seems all normal versions use 3.3 - 3.45v
I forgot they were released as late as 1994, long after the 5v socket 4 Pentiums.
Reply 9 of 28, by Sutekh94
oerk wrote:
It seems to have onboard LAN, is that correct?
Yup. NE2000 based, too, so drivers should be pretty easy to find.
My YouTube | My DeviantArt
Reply 10 of 28, by kin
Hmm ok I'll have a lookout on those cpu's.
Meanwhile doing homework: http://web.inter.nl.net/hcc/J.Steunebrink/amd5x86.htm
I might try to fit an AWE64 gold 😀 but it's about an 1/3 inch too long. Could consider extending the panel a bit with a segment, but need to extend the floppydrive and powerbutton + new click-in tabs left and right... without destroying the original structure. 😀
Before this I have the Geode MX one with similar casedesign... it was pita to get the ac97 work correctly in dos and the bottleneck with some of the games is the lack of linear framebuffer.
Reply 11 of 28, by PhilsComputerLab
Just go with a regular / value AWE64. It fits into this machine without any modifications.
Reply 12 of 28, by kin
Got a KFC CA6013DS 9 inch VGA monitor from a local auction for just only 10 euro's 😀.
It was kinda dim, so I removed the casing and checked the inside, adjusted the G2 slightly.
It is powered by the Unisys's IEC female port 😀.
Excuse me for the poor evening lighting. It's hard to focus on the monitor's lightsource and balancing the surroundings.
    143.6 KiB
    Transport Tycoon Deluxe (my favourite)
    86.94 KiB
    Running Gem 1.2
    62.07 KiB
    Running Mpxplay playing MP3's (48kbit 22050Hz, CPU at 71%)
    101.43 KiB
    Doom II ;)
Reply 13 of 28, by AlphaDangerDen
kin wrote:
Got a KFC CA6013DS 9 inch VGA monitor from a local auction for just only 10 euro's :). It was kinda dim, so I removed the casing […]
What keyboard is that? I believe I saw that exact same model keyboard around 10 years ago at my father's workplace.
Reply 15 of 28, by AlphaDangerDen
kin wrote:
That's the BTC 5100C. A cheap rubberdome keyboard.
Ah the keyboard I'm thinking about looks similar but I recall the switches being tactile, as if they had Alps or Cherry MX switches in them.
Reply 16 of 28, by snorg
That's a neat little machine, I have a very similar system also made by Unisys. I think yours uses 72 pin memory if my eyes are working correctly. How much RAM will it take? The only thing that bugs me about mine is it is stuck with 16MB max (which is a lot for DOS but about half what I want for a Win 95 & OS/2 dual boot system).
Reply 17 of 28, by kin
Yes, mine has 2x 8mb edo simm probably the original low profile shaped ones. I don't have anything beyond 8mb laying around, so I can't test it.
Reply 18 of 28, by dr.zeissler
That's a very important. Thx!
Any idea what lies on IRQ5, because NW is at 10.
I have lot's of trouble getting any soundcard working in that machine.
Reply 19 of 28, by dr.zeissler
@Phil
There are Versions of that CWD-4002 that came with a DX4/100 ?
I am wondering, if I could upgrade to a DX4/100 myself.
Where can I checkout if my System is able to manage the 3Volts for a DX4/100?
https://www.flickr.com/photos/94839221@N05/al … 157683681646872
Thx!
Doc
