First post, by MusicallyInspired
I've done some searching but can't seem to find an answer to my problem anywhere. I feel like I discovered this recently but I forget already. I could have been dreaming. Is there a way to get the command prompt to be affected by scalers? Via conf or a command line parameter? I'm trying to set something up on a new system and while the games are scaled fullscreen, the command prompt is a small box in the center of the screen. I know that setting the display to "overlay" is a way around this, but it's not a favourable option on this system. Also, I just simply would like to know how to use scalers on the command prompt like scanlines, etc if possible.
MuntVSTi Editor
FB-01 tools
Github
SC-55 Packs
Reply 1 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Add "forced" to the scaler setting, e.g. scaler=normal2x forced
