Windows XP does not regonize correctly the CPU
First post, by PCEnthusiast
Hello. I have a machine that has this problem (that unfortunately has worse specs than the Delux i use now, since it is an very old computer):
Elitegroup SI5PI AIO (REV. 1.1) Sockel 4
Pentium (yeah, that original Pentium) 20 MHz
64 MB RAM
SCSI Harddisk and IDE CD-ROM
Voodoo Rush PCI gpu
Set to dual boot Windows XP Home Edition and Windows 95
I kinda have a feel that the Pentium is underclocked.
I needed to change the board because XP was crashing always in the first step of installation. It is so slow on boot up, i need to wait seven minutes just to see the first icons (without the taskbar) then a few minutes and anything is ready.
While looking in system manager, this is what i see:
There is no cpu but the main chipset is correctly identifed..
Plz help me!!!!!!!
AMD Athlon 64 3000+ @ 200 Mhz, 1360x768, Realtek AC 97 HD, Genius Model. NO KB-0120, ATi Radeon Sapphire 9600 SE
Reply 1 of 6, by Skyscraper
I have a feeling we are beeing trolled 😁
Tinker with the FSB jumper block until you find the 66 MHz FSB setting and add a heat sink + fan!
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
Reply 2 of 6, by PCEnthusiast
No it isn't a troll. The minimum could XP ran is just 8 Mhz and 18 MB of Ram, And this PC haves 20 Mhz and 64 MB of Ram.
Where's the FSB??? I'm not a expert in computers.
Also there's a screenshot of the machine. Retro-cool it isn't retro-right?
So please help. Me.
Reply 3 of 6, by swaaye
Rank Moderator
Moderator
Look for jumpers for multiplier and bus clock. I can't read the CPU's markings in the photo but it looks like a Pentium 60. The bus clock should be 60 MHz in that case, and the multiplier 1x if there is a setting for it.
You should be running Windows 95, 98 or ME on that. Maybe NT4. XP is not exactly the ideal choice. 😀
Reply 4 of 6, by PCEnthusiast
Looked for jumperblock, then i found this. It looks like... something strange... probably the reason why the Pentium 60 Mhz de-tuned to 20 Mhz!
