First post, by awgamer
Do the OPL emulators in DOSBox use this info or similar?
https://docs.google.com/document/d/18IGx18NQY … 2nwo/edit?pli=1
http://yehar.com/blog/?p=665
Reply 1 of 1, by Jepael
Even before Olli and Matthew decapped the chip, the ymf262.c in MAME was done by reverse engineering and had this done correctly.
I think at some point DosBox used the MAME implementation, but the source code repository is down at the moment so I can't check.
