K6-III+ Rig, Ready for battle :)
First post, by Mamba
Hi folks,
I am building a K6-III+ rig with some "modern" pieces just to obtain good performance on DX8 games like Morrowind, I know it's really challenging, maybe impossible, but I try anyway.
Here the specs for now:
K6-III+ 500Mhz ANZ@ 110x5.5
Cooling unit Spire from a socket A machine (relatively quite)
GA-5AX Rev 5.2
1Gbyte RAM PC133 (1x512+2x256)
Leadtek Geforce FX5900XT 128Mbyte
Sata150 card Promise TX2
HD WDRaptor WD740HLFS
Audio Audigy SB1394
Tiny little PCI LAN card
Ali USB card with pinouts for front panel
Decent Itek PSU 550watt
I obtain some encouraging performance in XP SP3, with 3400points on 3Dmark2001SE, but it is not enough to play Morrowind at 1024x768.
The intro movie is really laggy, that makes me think there is something wrong on codecs combination.
In game, with default settings (no shadows) I obtain 10fps-15fps outdoor (Arriving in Seyda neen), 20-25 indoor.
Does the Audigy is a good card or maybe it slows down something? Better if I put a X-FI PCI? Or maybe an old PCI128?
I'm planning to install Win98SE with the unofficial patch 3.43. Would it be better?
I want to squeeze anything from it.
Thank you for suggestions.
Reply 1 of 36, by PhilsComputerLab
I'm not familiar with this game, but for DirectX 8, a Super Socket 7 machine is really not fast enough.
I'm thinking more of a Pentium 4 or Athlon XP for something like that. Should be very cheap to find parts, cheaper than decent SS7 gear.
YouTube, Facebook, Website
Reply 2 of 36, by ratfink
Pretty sure morrowind used to have awful performance on my athlon 2000xp, vga was either mx440 ir fx5200.
Reply 3 of 36, by Mamba
I know is a really impossible task, but I just want to obtain the maximum form this rig.
There is not only Morrowind to play obviously, I can play Civilization II, ATF Gold, USAF, IAF, lots of DX7/8 titles with my beloved K6-III+.
I use Morrowind just for a challenge.
Some suggestions on my doubts would be really nice.
Reply 4 of 36, by Mamba
What??
I used to play really nicely my first playtrough years ago on a P2B-F with a Pentium-III@1000Mhz and a Geforce MX440 (second with a Ti4200, much better AND DX8 effects).
Reply 5 of 36, by F2bnp
Morrowind really needs a fast CPU and lots of RAM. Otherwise, it's 20fps at best outside.
Reply 6 of 36, by Mamba
For RAM I am covered, as you see I have 1gbyte.
For CPU, well, that's why I started this thread, to obtain tips on speeding up my K6.
20fps outdoor would be really nice to see.
Any suggestions about the issue with intro movie?
Does changing Audio card would Help?
I read about some strange behaviour with Live! cards and socket7, does the Audigy do the same?
Now I'm installing Win98SE and the USP3.43
Reply 7 of 36, by dr_st
Sounds like a pretty big waste of time and effort... 😐
Reply 8 of 36, by F2bnp
You will not achieve 20FPS outdoors with a K6-III+. Even a Pentium 4 at 3.2GHz will have a hard time maintaining a framerate upwards of 30-40 outdoors AFAIR. It depends on draw distance among other things, but Morrowind is an amazing CPU hog due to how unoptimised it is.
The intro movie is slow due to the CPU. I don't think there's any work around to that.
Reply 9 of 36, by sliderider
I'm not really sure any K6-III system is going to be up to the task of Morrowind even with a powerful video card. It's a CPU intensive game and a K6-III isn't enough CPU. I know the minimum specs say 500mhz CPU, but games rarely run smoothly on the minimum hardware spec. The official spec also says P-III, Celeron, or Athlon, so I don't think a 500mhz K6 class CPU is going to have enough FPU power. I know it didn't run well on my Compaq K6-2 533 system.
Reply 10 of 36, by swaaye
Morrowind is very inefficient. It doesn't cull unseen polygons, other than beyond the view distance clip plane. I've seen some comments that it may render back to front. I remember needing an Athlon 64 to really get it running fast finally and I guesstimate that is about 20x faster than a K6-3+.
Reply 11 of 36, by GeorgeMan
On retrogaming, I always look at the recommended specs to run a game, and try to have a computer at least somewhat faster than these, if I want to play it smoothly on full details.
I understand people trying to be "period correct", which means having a low end 486 to play Doom for example, but if you have the choice, and the game plays well on newer hardware, and this hadrware is cheap, I think it's a bad choice to stay and be stuck at low framerates.
HP Elitebook 14 G1a | Snapdragon 12core | 32GB LPDDR5X RAM | Adreno GPU | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Windows 11 on ARM --> pcem ARM | Eden & Dolphin ARM editions
Reply 12 of 36, by Mamba
For now I am having a lot of pain in the @ss trying to make work Win98SE with USP3...
Finally surfong the web is acceptable with Opera, KernelEX seems to be nearly useless (it crashes anyway).
The Audigy drivers has been another problem, they where really difficult to find and install.
Now it seems to be all ok.
I overclocked the K6-III+ to 633Mhz (115x5.5) but it was unstable, revert to 605.
Downloaded Rivatuner, I'll try to overclock the FX5900XT and then I'll launch 3dmark2001SE
Reply 13 of 36, by F2bnp
Unfortunately, you won't see any performance increase by overclocking your FX card. The game is severely bottlenecked by the CPU at this point.
Reply 14 of 36, by Mamba
Before trying Morrowind, I'm realizing that in Win98SE +3.43 I got really WORSE performance than XP SP3 with the same configuration.
I installed the unofficial service pack 3.43 but it seems I only overcumbered the rig.
That is a little strange, I was thinking that win98 could be faster for K6.
Well maybe I was wrong... Or maybe I have to leave Win98SE SP1 unmodified to obtain a faster system.
Reply 15 of 36, by Standard Def Steve
XP is almost always faster than Win98 in CPU-bound situations. Well, unless you're using like a P120. 😁
You might want to try Win2000 as well. It sometimes benches slightly higher than XP, not that that's going to fix your Morrowind performance issues.
Still, I really like your setup. I've always been a fan of taking different platforms and completely maxing them out, and you've certainly done that with your K6-III!
"A little sign-in here, a touch of WiFi there..."
Reply 16 of 36, by Mamba
Thank you,
Yes I'll try Win2000 and see how it will perform.
Maybe it will be too slow for Morrowind, but I don't care. It will be a perfect rig for win98/DOS games.
Reply 17 of 36, by Mamba
Uhm...
Installed Win2000 with SP4.
I got abysmall performance with 3DMark2001 (2400 points.... 1000 points less than XP).
That's weird... Isn't win2000 supposed to be more fast?
I think I'll revert to XP SP3.
Someone at K6plus managed to hit 4000 points with the same 5900xt on a P5A and a K6-III@600Mhz.
Really don't know how...
Reply 18 of 36, by falloutboy
The key was the driver version 52.16 under Windows98SE. DirectX Version can also be important.
My System gave me 3493 3dMarks.
K6-III+@550 MHz 100 MHz FSB
Tyan S1590 1MB cache
256 MB RAM
FX5900XT driver 52.16
Under Windows98:
Geforce3 gave me always higher framerates, specially in older OpenGL games like Kingpin and older direct3d games like Viper Racing.
Tomb Raider 2 was even to slow on the FX5900XT, in areas with lots of water framerate dropped below 20 fps.
GF3 Driver was here 12.90, 14.10
For older games (<directx8) a Geforce2 should be even faster than the GF3.
It was DonPedro AFAIK
Reply 19 of 36, by Mamba
Yes it was DonPedro.
I used the exact combination of drivers he used.
I obtained less then 3400 and with a fx5700 and XP on an MVP3G2 I get the same. I started the thread.
I don't understand...
