First post, by jp7152
Hi,
I've had a good look through the search and in the end just managed to confuse myself really.
Could anyone advise me as to a decent native Tualatin motherboard? I would like to use the 1.4ghz model.
The board that keeps popping up in previous threads is the Asus TUSL2 but they are mega money on ebay.
Thanks !
Reply 1 of 43, by tayyare
Mine is Gigabyte GA-6VTXE. I purchased it as a replacement for existing GA-6VXE7+ and used with a coppermine 1000 for a time, happily. Now it has a 1.4 Tualatin and I'm even happier..😀
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 2 of 43, by jp7152
Thanks,
Looks like they are quite hard to come by also
Slightly off topic but can I ask also how you installed 95 98 and ME together?
I tried using an old version of System Commander but my TFT didn't support the resolution it was trying to use on boot and I got an 'out of range' message.
Thanks
Reply 3 of 43, by Stermy57
In my opinion during this period (few months) Tualatin's mainboard are became hard to find and more expensive.
Do you need overclock settings?
Reply 4 of 43, by PhilsComputerLab
My tip is to keep your eye out for OEM boards. I have two from Acer that are fully Tualatin compatible with the Intel 815 chipset. The challenge is finding out which board is actually compatible.
YouTube, Facebook, Website
Reply 5 of 43, by silikone
Which Tualatin boards are compatible with the Pentium 3 S version? I heard that some non-server boards refuse to work with them.
Do not refrain from refusing to stop hindering yourself from the opposite of watching nothing other than that which is by no means porn.
Reply 6 of 43, by meljor
I have 2 Asus Tusl2-c boards, They are the best imho.
Reply 7 of 43, by kixs
I have one QDI SynactiX 5EP V2.0 with Intel 815EP chipset running Tualatin S 1.4GHz cpu right on my desk now with box and manual.
Visit my AmiBay items for sale (updated: 2025-03-14). I also take requests 😉
Reply 8 of 43, by luckybob
and when you decide to wear the big-boy pants, you can get boards like the Tyan S2688, the Intel SDS2, or the Supermicro P3TDE6-G
Reply 9 of 43, by gg1978
I have an Asus TUV4X, as well as an Intel SDS2.. Both have their good points, if the SDS2 had an AGP slot it would be perfect 😀
Reply 10 of 43, by Stermy57
Maybe it could be but have you ever used Abit ST6 Raid?
Reply 11 of 43, by Skyscraper
If you can find a really cheap CUSL2 then you could perhaps fit a modified Tualatin from Ebay into the budget?
Finding a cheap TUSL2 seems pretty much impossible, at least in Sweden but I see CUSL2 boards very often.
Reply 12 of 43, by Stermy57
Are you talking about this pinmod?
http://www.mrufer.ch/pc/tualatin2_e.html
You will able to run only Tualatin that works with 1.5v with this mod if you do this mod with Tualatin that works with 1.45-1.475v, you will have problems ( crash, blue screen etc)
Reply 13 of 43, by Skyscraper
Stermy57 wrote:
Are you talking about this pinmod? http://www.mrufer.ch/pc/tualatin2_e.html […]
No we are talking about this mod which probably is pretty similar. It works fine as long as the motherboard supports the Tualatin voltage range and has BIOS support, CUSL2 runs these CPUs perfectly. I have 3 of these, all of them have a stock vid of 1.45v.
http://www.ebay.com/itm/Tualatin-P-IIIs-1-4GH … =item417b1c3fc1#
Reply 14 of 43, by Stermy57
Skyscraper wrote:
No we are talking about this mod which probably is pretty similar. It works fine as long as the motherboard supports the Tualati […]
Woow great point 😀
I didn't know this adapter I have to buy one of them
But I think is hard to find on my country 🙁
Reply 15 of 43, by Skyscraper
Stermy57 wrote:
Woow great point 😀
This Korean guy on Ebay will sell you an adapter without the CPU but the adapter isnt easy to install so its better to just buy the whole CPU with the socket adapter already soldered to it. You get a discount if you buy more than one as the shipping is included in the price. He has the Celeron 1400 aswell in case someone needs 100 MHz FSB, I run one of those in an Abit BH6 with a FCPGA slotket.
Reply 16 of 43, by meljor
Good point, i didn't. I tested a few through the years and the Tusl2-c is my favorite. I do have a preference for asus boards (but the asus tuv4x is far less stable with agp cards) but sure, there are more great boards.
Abit made great boards (as did for example epox, aopen and msi) but i had far less problems with leaking capacitors or doa with asus boards. Almost every used Asus board that came in my house simply worked, as almost EVERY msi board and epox board was dead. Abit and Gigabyte were somewhere in the middle, some worked, some didn't.
That experience (and features, stability) makes me a fan of Asus but other people will have other experiences. With hardware as old as 15-25 years it can very well be simply luck.
Reply 17 of 43, by tayyare
jp7152 wrote:
Thanks, […]
Thanks,
Thanks
Sorry, I didn't see your post, so I'm a bit late. My favorite multibooter is a small dos package called "Master Booter" and you can find it in here:
http://www.masterbooter.com/main/news.php?lang=en
I have the registered version (30 USD) which can boot 8 different systems, but even shareware version is able to boot 3 systems. It is a very nice package, easy to use, it's bootable floppy image is fantastic, and its documentation is very helpful. This one is a text mode booter, so I don't think you will have a problem with your monitor.
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 18 of 43, by tayyare
Stermy57 wrote:
Woow great point 😀
I don't think so:
http://www.ebay.com/itm/281238323137?_trksid= … K%3AMEBIDX%3AIT
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 19 of 43, by Stermy57
tayyare wrote:
Stermy57 wrote:
Woow great point 😀
I don't think so:
I want to buy a similar CPU from my country
I came from Italy and this seller lives far away
