Minimized Program
First post, by ik8ozv
Hello,
i would like to know if i can start a program in Dosbox as minimized.
If yes please which is the procedure?
Thanks
Enzo
Reply 1 of 11, by Solarstorm
Why would you want to start a game minimized?
My YouTube Channel
Reply 2 of 11, by ik8ozv
I said a program not a game
Reply 3 of 11, by Solarstorm
Well, Dosbox is meant for gaming only.
My YouTube Channel
Reply 4 of 11, by ik8ozv
I use it also for programs and it work great but i need a program that has to run as i load Windows and in minimized mode
Reply 5 of 11, by Solarstorm
Then you have your first problem with Dosbox because it's meant for gaming and not applications.
My YouTube Channel
Reply 6 of 11, by dr_st
The question itself makes little sense. DOSBox does not have a Window manager in itself. DOSBox programs do not run inside windows. It is DOSBox itself that runs (optionally) in a window. So the question should be - can you start DOSBox minimized.
Reply 9 of 11, by dr_st
Dominus wrote:
And isn't that managed by the shortcut in Windows?
It is, but since the DOSBox status window opens first, that's the one affected by the shortcut options. The DOSBox main window ignores them.
Reply 11 of 11, by purmike
...although the topic is very old I want to share my solution. I recompiled the sdl.dll to hide the dosbox main window.
When using the param "-noconsole" doxbox runs totally in the background.
