First post, by moknok
Just want to say
Jane's WW2 Fighters (A stunning game)
Running good on windows 7 64bit with dgvoodoo wrapper.
https://www.youtube.com/watch?v=cVmINMa6UTc
real ww2 pilots used to test it
https://www.youtube.com/watch?v=W_LHFecwURA
| WIN98SE non OEM | PII MMX | 350Mhz | 384RAM | Voodoo3 2000 PCI | DX7 | 126GB+ | Yamaha DS-XG Sound |
Reply 1 of 7, by Davros
Why use dgvoodoo ?
ww2 fighters also supports opengl
Reply 2 of 7, by Marty2dos
Yes, on Windows 7 64bit running very smooth. I use nGlide and turn the resolution to 4k with Aspect Ratio nGlide Settings 4:3 🤣
Reply 3 of 7, by leileilol
Pretty certain it was a Direct3D6 game.
Reply 4 of 7, by Expack3
It is, but it also supports Glide and OpenGL: http://www.mobygames.com/images/covers/l/2282 … -back-cover.jpg
To quote from that image:
Graphics: 3-D graphic[sic] accelerator compatible with Glide 3.0, Direct3D, or OpenGL (with full ICD support)
Reply 5 of 7, by Marty2dos
Expack3 wrote:
It is, but it also supports Glide and OpenGL: http://www.mobygames.com/images/covers/l/2282 … -back-cover.jpg […]
Yes ist Support OpenGL. But the Developer ....... The ww2.exe search the OpenGL32.dll in C:\Windows\System\ not System32 (and SysWow64 < x86 for 64Bit OS). Place the OpenGL32.dll in C:\Windows\System\ and you see in the 3D Setup
- D3d Prmary Device Driver
- 3DFX (is you has nGlide or .....)
- OpenGL
But with Default Sys OpenGl32 it only Show 640x480 16Bit. You can try and edit the ww2.ini.
Reply 6 of 7, by Yasashii
OMG! My childhood! I need this game, now!
I distinctly remember that there were some graphics issues on Windows XP with some GFX cards. I hope that's not the case on win7.
Edit: Nope. Works just fine on Windows 7 x64 SP1 using both D3D and nGlide.
Reply 7 of 7, by moknok
It's too bad Jane's Combat Sims went under 🙁
Grew up on Longbow myself, but never got to play ww2 fighters until this year.
They also made another ww2 game called attack squadron
