First post, by nemail
Hi
finally I have found time to continue building my P54CS Build currently consisting of:
Asus P/I-P55TVP4 Rev 1.5
Pentium 166MHz (P54CS, no MMX)
Diamond Viper V330 (Riva 128)
16MB SD-RAM
512k COAST
ST32122A (primary)
WDC AC2850F (secondary) 🤣 I just realized that this one has only 853MB
LITE-ON LTR-52327S CD-RW
Formosa SC1616 ESS AudioDrive ES1688F ISA Soundcard (might put that in some DOS gaming machine later due to the fabulous OPL3)
I like this system very much because it kind of reflects a boosted version of my first own new-bought PC I got when I was nine.
Unfortunately it is in a quite ugly case because it was the only spare one I had 🙁
And the ODIN RTC Battery is empty AND soldered, so I'll have to solder a socket to the mainboard and then replace the RTC. Does anyone know if the modern DALLAS DC12887+ modules are compatible to the ODINs? DC12887+ are rather cheap and easy to get where I live (brand new ones).
