Games you can play with a Riva 128?
First post, by GeorgeMan
Hello forum!
Recently I aqcuired an Nvidia Riva 128 PCI with 4MB of memory and I'm wondering, what 3D games I can play with it.
I never owned a PCI vga with 3D capability other than Voodoo graphics so I'm kinda excited!
I dislike FPS games and like turn-based stuff and racing ones.
So, fellow VOGONerS, what do you suggest me to try?
The only one I desperately want to try is Final Fantasy VII, which I think it's got a patch for the whole Nvidia Riva series. 😀
Thanks in advance!
HP Elitebook 14 G1a | Snapdragon 12core | 32GB LPDDR5X RAM | Adreno GPU | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Windows 11 on ARM --> pcem ARM | Eden & Dolphin ARM editions
Reply 2 of 26, by boxpressed
The Riva 128 was my first 3D accelerator. One of my favorite gaming experiences was completing FF7 with a Riva 128 on a K6-2 system back in the day.
I bought the Riva (STB brand) at retail, and the game bundle included Interstate '76, Motoracer, and a FIFA game.
Reply 3 of 26, by swaaye
Riva 128 is one quirky, ugly, but fast (for 97) GPU.
Reply 4 of 26, by Jorpho
I guess SepterraCore, Rollcage, and Deathkarz come to mind. Maybe Anachronox, but a 4 MB card probably won't be nearly enough for that. (I used my 12 MB Voodoo2 for that when I first got it.)
If I'm not mistaken, that patch ultimately enables use of the game with all D3D cards. In any case, fanmade fixes for FFVII are now widely available and it is no trouble at all to get it running pretty much anywhere, even if you don't want to buy the new Steam version (which is pretty much just the original version pre-combined with those fanmade fixes, if I'm not mistaken). You may want to consider the patch that enables the use of the original PSX soundtrack, for instance.
Reply 5 of 26, by leileilol
Jedi Outcast. 😀
While not really recommended for id tech3 games it CAN work with them. Probably not Call of Duty though but JK2 works. Try to prefer vertex lighting where available so there's no terrible blend precision killing off texture quality
Reply 7 of 26, by GeorgeMan
Thanks for the replies! I thought that you might not "play any game from 1997", as it's DX5 only. 😀
A socket 7 system can emulate a 386 and 486, so I don't think I'm going to hunt a PCI 486.
@RacoonRider I've already read this, but thanks!
It seems that I'll start hunting pretty old 3D games that currently I'm not aware of.
Reply 8 of 26, by swaaye
NVidia put a lot of work into Riva 128 drivers. It can run 1999 games like Quake3 and UT (in OpenGL mode). The problem is it has awful image quality because it's not a very robust GPU, which you will discover. 😉
You might enjoy having a Riva TNT to compare with. The leap in image quality is astonishing.
Reply 9 of 26, by GeorgeMan
I don't seem to be able to find a proper TNT. All I've ever had was the crippled model 64. Plus all of them were AGP, not PCI, so a no-go for most Pentium MMX systems.
Reply 10 of 26, by PhilsComputerLab
That has been EXACTLY my issue as well!
What I did was look for specific models of TNT2. For example Diamond Viper V770. I got two of them recently by searching directly. Haven't received them yet though.
Reply 11 of 26, by squareguy
Tongue-in-cheek: Any game you want to look like crap. <-- insert banned word for crap
Sorry, hard to resist a joke. I just remember the Riva 128 having horrible display quality.
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
Reply 12 of 26, by GeorgeMan
You mean overall display quality or just crappy-3D?
Because my TNT has pretty sharp image in Windows. I'm talking about 800x600 and 1024x768 @ 16bit, nothing fancy. 😀
Reply 13 of 26, by filipetolhuizen
The latest Diamond drivers for their Riva128 added DX6 capabilities.
Reply 14 of 26, by idspispopd
3D is not crappy, but dithering is not too nice, image can be grainy/noisy. A good read is http://www.vintage3d.org/riva128.php (also the gallery).
Riva 128 was the first mainstream PC 3D accelerator which both integrated 2D and exceeded Voodoo1 performance. Compatibility for games of that era should be quite good since it was rather common.
Reply 15 of 26, by Trevize
Did anybody play Ignition (Wikipedia) back then? 😀
Reply 17 of 26, by GeorgeMan
Just did a quick bench about DOS performance. I used Phil's dos bench. Test machine was a P 166MMX, 64MB SDR and the other candidates were an S3 Vision 968 4MB VRAM (1995) and a Voodoo3 2000 16MB SGRAM (1999).
Well, Riva 128 was the fastest amongst the others. Voodoo3 could only match it in a few tests. S3 was left a little behind. All of them had very good image quality. 😁
Reply 18 of 26, by amadeus777999
A blast on a LAN but it used to crash quite often. Having a dos- and win.exe out of the box was a nice oddity too.
