First post, by MP
Hello all ! When i'm using VDMS to play might&magic, the sound play too slowly, isn't there a way to speed up the sound with VDMS?
Reply 1 of 5, by eL_PuSHeR
Rank Moderator
Moderator
Have you tried Speedset?
EDIT: Or play with VDMSound advanced options. Like Capping DOS timer frequency or trying to use little CPU use. Sometimes they help pinpointing the proper speed.
Reply 3 of 5, by MiniMax
Rank Moderator
Moderator
MP/Guest, which version of VDMSound do you use? Do you use the LaunchPad?
In the VDMSound Docs directory, you will find SpeedSet.RTF. Read it.
_________________
Reply 5 of 5, by MiniMax
Rank Moderator
Moderator
Guest, I am at a slight disadvantage, since I use the 2.1.0 beta.... When installed, it has a 'Docs' sub-directory with 3-4 small documents, including the SpeedSet.RTF file.
You do not have a 'Docs' subdirectory?
Okay, it is just 2 KB, so I guess I just link it in here... Please wait....
    speedset.rtf
    1.66 KiB
    148 downloads
    Intro to the SpeedSet program.
_________________
