First post, by CaptPete2003
Windows 7 64-bit with DOSBOX 0.74 on a Samsung R580 Laptop.
When I run Keymapper and map the keys not recognized by DOSBOX (`=[]\') and then save the map and exit the keys work fine as long as I don't exit DOSBOX. The map is saved in my username/AppData/Local/DOSBOX directory. If I then open DOSBOX it says it's using the map but the keys return nothing on the command line. If I then open the map file all those keys have "key 0". If I manually type in the correct scan codes, save the file, and open DOSBOX the keys still return nothong on the command line. Here are the map files and the scan codes:
The Keymapper-generated map:
hand_shutdown "key 290 mod1"
hand_capmouse "key 291 mod1"
hand_fullscr "key 13 mod2"
hand_pause "key 19 mod2"
hand_mapper "key 282 mod1"
hand_speedlock "key 293 mod2"
hand_recwave "key 287 mod1"
hand_caprawmidi "key 289 mod1 mod2"
hand_scrshot "key 286 mod1"
hand_video "key 286 mod1 mod2"
hand_decfskip "key 288 mod1"
hand_incfskip "key 289 mod1"
hand_cycledown "key 292 mod1"
hand_cycleup "key 293 mod1"
hand_caprawopl "key 288 mod1 mod2"
hand_swapimg "key 285 mod1"
key_esc "key 27"
key_f1 "key 282"
key_f2 "key 283"
key_f3 "key 284"
key_f4 "key 285"
key_f5 "key 286"
key_f6 "key 287"
key_f7 "key 288"
key_f8 "key 289"
key_f9 "key 290"
key_f10 "key 291"
key_f11 "key 292"
key_f12 "key 293"
key_grave "key 0"
key_1 "key 49"
key_2 "key 50"
key_3 "key 51"
key_4 "key 52"
key_5 "key 53"
key_6 "key 54"
key_7 "key 55"
key_8 "key 56"
key_9 "key 57"
key_0 "key 48"
key_minus "key 45"
key_equals "key 0"
key_bspace "key 8"
key_tab "key 9"
key_q "key 113"
key_w "key 119"
key_e "key 101"
key_r "key 114"
key_t "key 116"
key_y "key 121"
key_u "key 117"
key_i "key 105"
key_o "key 111"
key_p "key 112"
key_lbracket "key 0"
key_rbracket "key 91"
key_enter "key 13"
key_capslock "key 301"
key_a "key 97"
key_s "key 115"
…Show last 86 lines
key_d "key 100"
key_f "key 102"
key_g "key 103"
key_h "key 104"
key_j "key 106"
key_k "key 107"
key_l "key 108"
key_semicolon "key 59" "key 59"
key_quote "key 0"
key_backslash "key 93"
key_lshift "key 304"
key_lessthan "key 60"
key_z "key 122"
key_x "key 120"
key_c "key 99"
key_v "key 118"
key_b "key 98"
key_n "key 110"
key_m "key 109"
key_comma "key 44"
key_period "key 46"
key_slash "key 47"
key_rshift "key 303"
key_lctrl "key 306"
key_lalt "key 308"
key_space "key 32"
key_ralt "key 307"
key_rctrl "key 305"
key_printscreen "key 316"
key_scrolllock "key 302"
key_pause "key 19"
key_insert "key 277"
key_home "key 278"
key_pageup "key 280"
key_delete "key 127"
key_end "key 279"
key_pagedown "key 281"
key_up "key 273"
key_left "key 276"
key_down "key 274"
key_right "key 275"
key_numlock "key 300"
key_kp_divide "key 267"
key_kp_multiply "key 268"
key_kp_minus "key 269"
key_kp_7 "key 263"
key_kp_8 "key 264"
key_kp_9 "key 265"
key_kp_plus "key 270"
key_kp_4 "key 260"
key_kp_5 "key 261"
key_kp_6 "key 262"
key_kp_1 "key 257"
key_kp_2 "key 258"
key_kp_3 "key 259"
key_kp_enter "key 271"
key_kp_0 "key 256"
key_kp_period "key 266"
jbutton_0_0
jbutton_0_1
jaxis_0_1-
jaxis_0_1+
jaxis_0_0-
jaxis_0_0+
jbutton_0_2
jbutton_0_3
jbutton_1_0
jbutton_1_1
jaxis_0_2-
jaxis_0_2+
jaxis_0_3-
jaxis_0_3+
jaxis_1_0-
jaxis_1_0+
jaxis_1_1-
jaxis_1_1+
jbutton_0_4
jbutton_0_5
jhat_0_0_0
jhat_0_0_3
jhat_0_0_2
jhat_0_0_1
mod_1 "key 305" "key 306"
mod_2 "key 307" "key 308"
mod_3
The hand-edited map:
key_esc "key 27"
key_f1 "key 282"
key_f2 "key 283"
key_f3 "key 284"
key_f4 "key 285"
key_f5 "key 286"
key_f6 "key 287"
key_f7 "key 288"
key_f8 "key 289"
key_f9 "key 290"
key_f10 "key 291"
key_f11 "key 292"
key_f12 "key 293"
key_grave "key 192"
key_1 "key 49"
key_2 "key 50"
key_3 "key 51"
key_4 "key 52"
key_5 "key 53"
key_6 "key 54"
key_7 "key 55"
key_8 "key 56"
key_9 "key 57"
key_0 "key 48"
key_minus "key 45"
key_equals "key 187"
key_bspace "key 8"
key_tab "key 9"
key_q "key 113"
key_w "key 119"
key_e "key 101"
key_r "key 114"
key_t "key 116"
key_y "key 121"
key_u "key 117"
key_i "key 105"
key_o "key 111"
key_p "key 112"
key_lbracket "key 219"
key_rbracket "key 221"
key_enter "key 13"
key_a "key 97"
key_s "key 115"
…Show last 86 lines
key_d "key 100"
key_f "key 102"
key_g "key 103"
key_h "key 104"
key_j "key 106"
key_k "key 107"
key_l "key 108"
key_quote "key 222"
key_backslash "key 220"
key_z "key 122"
key_x "key 120"
key_c "key 99"
key_v "key 118"
key_b "key 98"
key_n "key 110"
key_m "key 109"
key_comma "key 44"
key_period "key 46"
key_slash "key 47"
key_lctrl "key 306"
key_lalt "key 308"
key_space "key 32"
key_ralt "key 307"
key_rctrl "key 305"
key_pause "key 19"
key_home "key 278"
key_end "key 279"
key_up "key 273"
key_left "key 276"
key_down "key 274"
key_right "key 275"
key_kp_7 "key 263"
key_kp_8 "key 264"
key_kp_9 "key 265"
key_kp_4 "key 260"
key_kp_5 "key 261"
key_kp_6 "key 262"
key_kp_1 "key 257"
key_kp_2 "key 258"
key_kp_3 "key 259"
key_kp_0 "key 256"
jbutton_0_0
jbutton_0_1
jaxis_0_1-
jaxis_0_1+
jaxis_0_0-
jaxis_0_0+
jbutton_0_2
jbutton_0_3
jbutton_1_0
jbutton_1_1
jaxis_0_2-
jaxis_0_2+
jaxis_0_3-
jaxis_0_3+
jaxis_1_0-
jaxis_1_0+
jaxis_1_1-
jaxis_1_1+
jbutton_0_4
jbutton_0_5
jhat_0_0_0
jhat_0_0_3
jhat_0_0_2
jhat_0_0_1
mod_3
The actual scan codes (produced by KeyCodes3):
OnKeyPress `
OnKeyup, Key code=192, Control keys=, Key name ........OEM specific
OnKeyPress =
OnKeyup, Key code=187, Control keys=, Key name ........OEM specific
OnKeyPress [
OnKeyup, Key code=219, Control keys=, Key name OEM specific
OnKeyPress ]
OnKeyup, Key code=221, Control keys=, Key name ........OEM specific
OnKeyPress \
OnKeyup, Key code=220, Control keys=, Key name ........OEM specific
OnKeyPress '
OnKeyup, Key code=222, Control keys=, Key name ........OEM specific
Can anyone help with this?
By the way both my wireless and bluetooth keyboards produce the same results.
"In the future, everyone will have their own boring home page." - Andy Warhol overheard chatting with Nico, 1967.
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
Does this apply to your system ?
Right-Shift / Backslash Keyboard Problems (SOLVED!)
What about the usescancode option ?
Although it might a similar problem as the one I recently fixed, where the winkey couldn't be mapped on Linux.
Water flows down the stream
Reply 2 of 3, by CaptPete2003
"usescancodes=true" is set in my dosbox.conf, changing it to "false" makes no difference.
Well since I have a Samsung (Korean) laptop I do have the MCIR 109 keyboard driver mentioned. I'm not sure I'm ready to mess with changing drivers at this moment. ALL my other emulators/simulators read the keys, only regular DOSBOX doesn't.
As an aside I downloaded and tried the Daum-SVN version of DOSBOX and that works correctly so I still see it as a DOSBOX problem.
Reply 3 of 3, by CaptPete2003
Just to be clear, if I run DOSBOX and define the keys with Ctrl-F1, save and exit back to DOSBOX they work. It's the Keymapper that does not save, or recognize the scan codes for those keys. It's the keymapper that needs a fix as far as saving the scan codes, DOSBOX itself works fine with the keys IF I DEFINE THEM EACH TIME I RUN DOSBOX.
