First post, by keropi
Hiya!
I noticed that if you have a GUS and a SB in your system Quake always defaults in using the GUS soundcard.
If you remove the ULTRASND variable then Quake uses the SB.
Is there a command line option to force using SB and avoid messing with the GUS variable?
Thanks in advance for any info! 😊
🎵 PCMIDI mpu site buy+info
🎧 WIP Orpheus soundcard site
Reply 2 of 11, by keropi
wow, didn't expect that
thanks for the help , now I don't need to search more on this... nothing a batch file can't fix I suppose 😁
Reply 3 of 11, by leileilol
For reference here's all the sound-related parameters
-dsp # : Specify Sound Blaster DSP to try. 2, 3, 4 accepted (SB2.0, SBPro and SB16 respectively). Useful for reducing sound quality.
-sspeed ##### : Specify sampling rate, default 11025. (fyi: Quake has roughly four 22khz16bit sounds - lightning, rotfish and shub's ending groan). Also applies to GUS (in which it'll round down to the nearest supported rate by the GUS)
-nosound : turns off osund completely
-simsound : turns off sound output, but still processes the data in a fake dma buffer (useful for performance profilng and debugging sound issues)
-nocdaudio : turns off CD audio. Quake will bug you about using this if you don't have MSCDEX loaded anyway
Reply 5 of 11, by keropi
^ will give it a go, thanks for the heads up 😁
I wonder if it works faster than stock Q ...
Reply 6 of 11, by Maraakate
There's no visual enhancements so it should be about the same speed. It's compiled on the new DJGPP and GCC builds so in theory it should generate better code, but I never tested that out for sure. Runs great on target hardware of the era though.
Reply 7 of 11, by keropi
just tested, I get a +0.4fps speed boost 🤣
it's really nice and feels the same just with some extra welcomed options , nice work!
Reply 8 of 11, by leileilol
A little note, the released 1.09 sources have a mistake with the view refdef adding a few pixels of border to the viewport so the fps boost might be due to that
Reply 9 of 11, by Maraakate
leileilol wrote:
A little note, the released 1.09 sources have a mistake with the view refdef adding a few pixels of border to the viewport. so the fps boost might be due to that
where dat at?
Reply 10 of 11, by NewRisingSun
No, but you could open QUAKE.EXE with a hex editor and replace the strings ULTRASND and ULTRA16 with something else.
Reply 11 of 11, by keropi
didn't think of that 🤣
tbh it was for the best, I found about QDOS 😊
