First post, by superfury
I'm currently working on getting my FDC(Floppy Disk Controller) emulation correct. Anyone knows if this has any bugs? For some reason MS-DOS 3.3 (using the Turbo XT BIOS v2.5) won't start loading correctly. Single sector transfers (512 byte sectors at a time) seem to work, but multiple sectors at once seem to go wrong somehow (IO.SYS fails to load, looping loading it's high sectors (past sector 3) infinitely?)? Anyone can tell me what's going wrong?
#include "headers/types.h" //Basic typedefs!
#include "headers/hardware/8237A.h" //DMA controller support!
#include "headers/hardware/ports.h" //Port support!
#include "headers/bios/io.h" //Basic I/O functionality!
#include "headers/hardware/pic.h" //PIC support!
#include "headers/bios/dskimage.h" //DSK image support!
//Configuration of the FDC...
//Double logging if FLOPPY_LOGFILE2 is defined!
#define FLOPPY_LOGFILE "debugger"
#define FLOPPY_LOGFILE2 "floppy"
//What IRQ is expected of floppy disk I/O
#define FLOPPY_IRQ 6
//What DMA channel is expected of floppy disk I/O
#define FLOPPY_DMA 2
//Automatic setup.
#ifdef FLOPPY_LOGFILE
#ifdef FLOPPY_LOGFILE2
#define FLOPPY_LOG(...) dolog(FLOPPY_LOGFILE,__VA_ARGS__); dolog(FLOPPY_LOGFILE2,__VA_ARGS__);
#else
#endif
#else
#endif
typedef struct
uint_64 KB;
byte SPT;
byte sides;
byte tracks;
} FLOPPY_GEOMETRY; //All floppy geometries!
struct
union
struct
byte DriveNumber : 2; //What drive to address?
byte REST : 1; //Enable controller when set!
byte Mode : 1; //0=IRQ channel, 1=DMA mode
byte MotorControl : 4; //All drive motor statuses!
byte data; //DOR data!
} DOR; //DOR
union
struct
byte BusyInPositioningMode : 4; //1 if busy in seek mode.
byte CommandBusy : 1; //Busy: read/write command of FDC in progress. Set when received command byte, cleared at end of result phase
byte NonDMA : 1; //1 when not in DMA mode, else DMA mode, during execution phase.
byte HaveDataForCPU : 1; //1 when has data for CPU, 0 when expecting data.
byte RQM : 1; //1 when ready for data transfer, 0 when not ready.
…Show last 1152 lines
		byte data; //MSR data!
} MSR; //MSR
union
byte data; //CCR data!
} CCR; //CCR
union
byte data; //DIR data!
} DIR; //DIR
union
struct
byte DRATESEL : 2;
byte PRECOMP : 3;
byte DSR_0 : 1;
byte PowerDown : 1;
byte SWReset : 1;
byte data; //DSR data!
} DSR;
union
byte data; //ST0 register!
struct
byte UnitSelect : 2;
byte CurrentHead : 1;
byte NotReady : 1;
byte UnitCheck : 1;
byte SeekEnd : 1;
byte InterruptCode : 2;
} ST0;
union
byte data; //ST1 register!
struct
byte EndOfCylinder : 1;
byte Always0 : 1;
byte DataError : 1;
byte TimeOut : 1;
byte NoData : 1;
byte NotWritableDuringWriteCommand : 1;
byte NoAddressMark : 1;
} ST1;
union
byte data; //ST2 register!
} ST2;
union
byte data; //ST3 register!
} ST3;
union
byte data[2]; //Both data bytes!
struct
byte HeadUnloadTime : 4;
byte StepRate : 4;
byte NDM : 1;
byte HeadLoadTime : 7;
} DriveData[4]; //Specify for each of the 4 floppy drives!
byte commandstep; //Current command step!
byte commandbuffer[0x10000]; //Outgoing command buffer!
word commandposition; //What position in the command (starts with commandstep=commandposition=0).
byte databuffer[0x10000]; //Incoming data buffer!
word databufferposition; //How much data is buffered!
word databuffersize; //How much data are we to buffer!
byte resultbuffer[0x10]; //Incoming result buffer!
byte resultposition; //The position in the result!
uint_64 disk_startpos; //The start position of the buffered data in the floppy disk!
byte currentcylinder; //Current cylinder the floppy thinks we're at!
byte IRQPending; //Are we waiting for an IRQ?
byte DMAPending; //Pending DMA transfer?
byte diskchanged[4]; //Disk changed?
FLOPPY_GEOMETRY *geometries[4]; //Disk geometries!
FLOPPY_GEOMETRY customgeometry[4]; //Custom disk geometries!
byte reset_pending; //Reset pending?
byte currentcylinders[4], currenthead[4], currentsector[4]; //Current head for all 4 drives!
byte TC; //Terminal count triggered?
uint_32 sectorstransferred; //Ammount of sectors transferred!
byte MT; //MT bit, as set by the command, if any!
} FLOPPY; //Our floppy drive data!
//Normal floppy specific stuff
#define KB(x) (x/1024)
{ KB,SPT,SIDES,TRACKS, }
{ 160, 8, 1 , 40 , 0},
{ 180, 9, 1 , 40 , 0},
{ 200, 10, 1 , 40 , 0},
{ 320, 8, 2 , 40 , 1},
{ 360, 9, 2 , 40 , 1},
{ 400, 10, 2 , 40 , 1},
{ 720, 9, 2 , 80 , 3},
{1200, 15, 2 , 80 , 2},
{1440, 18, 2 , 80 , 4},
{2880, 36, 2 , 80 , 6},
FLOPPY_GEOMETRY geometries[] = { //Differently formatted disks, and their corresponding geometries
{ 160, 8, 1, 40 }, //160K 5.25"
{ 320, 8, 1, 40 }, //320K 5.25"
{ 180, 9, 1, 40 }, //180K 5.25"
{ 360, 9, 2, 40 }, //360K 5.25"
{ 720, 9, 2, 40 }, //720K 3.5"
{ 200, 10, 2, 40 }, //200K 5.25"
{ 400, 10, 2, 40 }, //400K 5.25"
{ 1200, 15, 2, 80 }, //1200K 5.25"
{ 1440, 18, 2, 80 }, //1.44M 3.5"
{ 2880, 36, 2, 80 }, //2.88M 3.5"
{ 1680, 21, 2, 80 }, //1.68M 3.5"
{ 1722, 21, 2, 82 }, //1.722M 3.5"
{ 1840, 23, 2, 80 } //1.84M 3.5"
//BPS=512 always(except differently programmed)!
//Floppy geometries
byte floppy_spt(uint_64 floppy_size)
int i;
for (i = 0; i<NUMITEMS(geometries); i++)
if (geometries[i].KB == KB(floppy_size)) return geometries[i].SPT; //Found?
return 0; //Unknown!
byte floppy_tracks(uint_64 floppy_size)
int i;
if (geometries[i].KB == KB(floppy_size)) return geometries[i].tracks; //Found?
byte floppy_sides(uint_64 floppy_size)
int i;
if (geometries[i].KB == KB(floppy_size)) return geometries[i].sides; //Found?
void updateFloppyGeometries(byte floppy, byte side, byte track)
uint_64 floppysize = disksize(floppy); //Retrieve disk size for reference!
byte i;
char *DSKImageFile = NULL; //DSK image file to use?
DISKINFORMATIONBLOCK DSKInformation;
TRACKINFORMATIONBLOCK DSKTrackInformation;
FLOPPY.geometries[floppy] = NULL; //Init geometry to unknown!
for (i = 0; i < NUMITEMS(geometries); i++) //Update the geometry!
if (geometries[i].KB == KB(floppysize)) //Found?
FLOPPY.geometries[floppy] = &geometries[i]; //The geometry we use!
return; //Stop searching!
//Unknown geometry!
if (DSKImageFile = getDSKimage(floppy ? FLOPPY1 : FLOPPY0)) //Are we a DSK image file?
if (readDSKInfo(DSKImageFile, &DSKInformation)) //Gotten information about the DSK image?
if (readDSKTrackInfo(DSKImageFile, side, track, &DSKTrackInformation))
FLOPPY.geometries[floppy] = &FLOPPY.customgeometry[floppy]; //Apply custom geometry!
FLOPPY.customgeometry[floppy].sides = DSKInformation.NumberOfSides; //Number of sides!
FLOPPY.customgeometry[floppy].tracks = DSKInformation.NumberOfTracks; //Number of tracks!
FLOPPY.customgeometry[floppy].SPT = DSKTrackInformation.numberofsectors; //Number of sectors in this track!
uint_32 floppy_LBA(byte floppy, word side, word track, word sector)
updateFloppyGeometries(floppy,side,track); //Update the floppy geometries!
if (!FLOPPY.geometries[floppy]) return 0; //Unknown floppy geometry!
return (uint_32)(((track*FLOPPY.geometries[floppy]->sides) + side) * FLOPPY.geometries[floppy]->SPT) + sector - 1; //Give LBA for floppy!
//Sector size
word translateSectorSize(byte size)
return 128*pow(2,size); //Give the translated sector size!
void FLOPPY_notifyDiskChanged(int disk)
switch (disk)
case FLOPPY0:
FLOPPY.diskchanged[0] = 1; //Changed!
break;
case FLOPPY1:
FLOPPY.diskchanged[1] = 1; //Changed!
break;
void FLOPPY_raiseIRQ() //Execute an IRQ!
FLOPPY.IRQPending = 1; //We're waiting for an IRQ!
doirq(FLOPPY_IRQ); //Execute the IRQ!
void FLOPPY_lowerIRQ()
FLOPPY.IRQPending = 0;
removeirq(FLOPPY_IRQ); //Lower the IRQ!
void FLOPPY_reset() //Resets the floppy disk command!
FLOPPY_LOG("FLOPPY: Reset requested!")
FLOPPY.DOR.MotorControl = 0; //Reset motors!
FLOPPY.DOR.DriveNumber = 0; //Reset drives!
FLOPPY.DOR.Mode = 0; //IRQ channel!
FLOPPY.MSR.data = 0; //Default to no data!
FLOPPY.commandposition = 0; //No command!
FLOPPY.commandstep = 0; //Reset step!
FLOPPY.ST0.data = 0xC0; //Reset ST0 to the correct value: drive became not ready!
FLOPPY.ST1.data = FLOPPY.ST2.data = 0; //Reset the ST data!
FLOPPY.reset_pending = 4; //We have a reset pending for all 4 drives!
FLOPPY.currentcylinder = 0; //Reset current cylinder!
memset(FLOPPY.currenthead, 0, sizeof(FLOPPY.currenthead)); //Clear the current heads!
memset(FLOPPY.currentcylinders, 0, sizeof(FLOPPY.currentcylinders)); //Clear the current heads!
memset(FLOPPY.currentsector, 0, sizeof(FLOPPY.currentsector)); //Clear the current heads!
FLOPPY.TC = 0; //Disable TC identifier!
FLOPPY_raiseIRQ(); //Raise the IRQ flag!
//Execution after command and data phrases!
void updateFloppyMSR() //Update the floppy MSR!
switch (FLOPPY.commandstep) //What command step?
case 0: //Command?
FLOPPY.sectorstransferred = 0; //There's nothing transferred yet!
FLOPPY.MSR.CommandBusy = 0; //Not busy: we're waiting for a command!
FLOPPY.MSR.RQM = 1; //Ready for data transfer!
FLOPPY.MSR.HaveDataForCPU = 0; //We don't have data for the CPU!
break;
case 1: //Parameters?
FLOPPY.MSR.CommandBusy = 1; //Default: busy!
break;
case 2: //Data?
//Check DMA, RQM and Busy flag!
switch (FLOPPY.commandbuffer[0]) //What command are we processing?
case 0x5: //Write sector?
case 0x9: //Write deleted sector?
case 0xD: //Format sector?
case 0x6: //Read sector?
case 0xC: //Read deleted sector?
FLOPPY.MSR.NonDMA = (!FLOPPY.DOR.Mode); //Not in DMA mode?
if (FLOPPY.MSR.NonDMA) //Not in DMA mode?
FLOPPY.MSR.RQM = 1; //Data transfer!
else //DMA mode transfer?
FLOPPY.MSR.RQM = 0; //No transfer!
break;
default: //Unknown command?
break; //Don't process!
//Check data direction!
switch (FLOPPY.commandbuffer[0]) //Process input/output to/from controller!
FLOPPY.MSR.HaveDataForCPU = 0; //We request data from the CPU!
break;
FLOPPY.MSR.HaveDataForCPU = 1; //We have data for the CPU!
break;
default: //Unknown direction?
FLOPPY.MSR.HaveDataForCPU = 0; //Nothing, say output by default!
break;
break;
case 3: //Result?
break;
case 0xFF: //Error?
break;
default: //Unknown status?
break; //Unknown?
void updateFloppyDIR() //Update the floppy DIR!
FLOPPY.DIR.data = (FLOPPY.diskchanged[0] || FLOPPY.diskchanged[1]); //Disk changed?
FLOPPY.diskchanged[0] = 0; //Reset!
FLOPPY.diskchanged[1] = 0; //Reset!
void updateFloppyTrack0()
FLOPPY.ST0.SeekEnd = (FLOPPY.currentcylinder == 0); //Are we at cylinder 0?
void updateFloppyWriteProtected(byte iswrite)
FLOPPY.ST1.data = (FLOPPY.ST1.data&~2); //Default: not write protected!
if (drivereadonly(FLOPPY.DOR.DriveNumber ? FLOPPY1 : FLOPPY0) && iswrite) //Read-only drive and tried to write?
FLOPPY.ST1.data |= 2; //Write protected!
byte floppy_increasesector(byte floppy) //Increase the sector number automatically!
byte result = 1; //Default: read/write more
if (FLOPPY.geometries[floppy]) //Do we have a valid geometry?
//cylinder/track=2;head=3;sector=4;max sector number=6
if (++FLOPPY.commandbuffer[4] > FLOPPY.commandbuffer[6]) //Overflow next sector by parameter?
if ((FLOPPY.MT&&FLOPPY.commandbuffer[3]) || (!FLOPPY.MT)) //Multi-track and side 1, or not Multi-track?
result = 0; //SPT finished!
FLOPPY.commandbuffer[4] = 1; //Reset sector number!
if (++FLOPPY.commandbuffer[3] >= FLOPPY.geometries[floppy]->sides) //Side overflow?
FLOPPY.commandbuffer[3] = 0; //Reset side number!
if (++FLOPPY.commandbuffer[2] >= FLOPPY.geometries[floppy]->tracks) //Track overflow?
FLOPPY.commandbuffer[2] = 0; //Reset track number!
FLOPPY.currentcylinder = FLOPPY.currentcylinders[floppy] = FLOPPY.commandbuffer[2]; //Our idea of the current cylinder!
FLOPPY.ST0.CurrentHead = FLOPPY.currenthead[floppy] = (FLOPPY.commandbuffer[3] & 1); //Our idea of the current head!
FLOPPY.currentsector[floppy] = FLOPPY.commandbuffer[4]; //Our idea of the current sector
if (FLOPPY.DOR.Mode) //DMA mode determines our triggering?
if (result) //OK to transfer more?
result = !FLOPPY.TC; //No terminal count triggered? Then we read the next sector!
else //Error occurred during DMA transfer?
result = 2; //Abort!
FLOPPY.ST0.InterruptCode = 1; //Couldn't finish correctly!
FLOPPY.ST0.SeekEnd = 0; //Failed!
++FLOPPY.sectorstransferred; //Increase the amount of sectors transferred.
return result; //Give the result: we've overflown the max sector number!
void FLOPPY_dataReady() //Data transfer ready to transfer!
if (FLOPPY.DriveData[FLOPPY.DOR.DriveNumber].NDM) //Interrupt for each byte transferred?
FLOPPY_raiseIRQ(); //Raise the floppy IRQ: We have data to transfer!
void FLOPPY_startData() //Start a Data transfer if needed!
FLOPPY.databufferposition = 0; //Start with the new buffer!
if (FLOPPY.commandstep != 2) //Entering data phase?
FLOPPY_LOG("FLOPPY: Start transfer of data...");
FLOPPY.commandstep = 2; //Move to data phrase!
if (FLOPPY.DOR.Mode) //DMA mode?
FLOPPY.DMAPending = 1; //Pending DMA!
FLOPPY_dataReady(); //We have data to transfer!
void floppy_readsector() //Request a read sector command!
SECTORINFORMATIONBLOCK sectorinformation; //Information about the sector!
FLOPPY.MT = (FLOPPY.commandbuffer[0] >> 7); //Multiple track mode?
FLOPPY.databuffersize = translateSectorSize(FLOPPY.commandbuffer[5]); //Sector size into data buffer!
if (!FLOPPY.commandbuffer[5]) //Special case? Use given info!
FLOPPY.databuffersize = FLOPPY.commandbuffer[8]; //Use data length!
FLOPPY_LOG("FLOPPY: Read sector: Sector size: %i bytes", FLOPPY.databuffersize)
FLOPPY.disk_startpos = floppy_LBA(FLOPPY.DOR.DriveNumber, FLOPPY.commandbuffer[3], FLOPPY.commandbuffer[2], FLOPPY.commandbuffer[4]); //The start position, in sectors!
FLOPPY_LOG("FLOPPY: Read sector #%i", FLOPPY.disk_startpos) //We're reading this sector!
FLOPPY.disk_startpos *= FLOPPY.databuffersize; //Calculate the start sector!
FLOPPY_LOG("FLOPPY: Requesting transfer for %i bytes.", FLOPPY.databuffersize); //Transfer this many sectors!
FLOPPY_LOG("FLOPPY: Read sector: CHS=%i,%i,%i; Params: %02X%02X%02x%02x%02x%02x%02x%02x", FLOPPY.commandbuffer[3], FLOPPY.commandbuffer[2], FLOPPY.commandbuffer[4], FLOPPY.commandbuffer[1], FLOPPY.commandbuffer[2], FLOPPY.commandbuffer[3], FLOPPY.commandbuffer[4], FLOPPY.commandbuffer[5], FLOPPY.commandbuffer[6], FLOPPY.commandbuffer[7], FLOPPY.commandbuffer[8]); //Log our request!
if (!(FLOPPY.DOR.MotorControl&(1 << FLOPPY.DOR.DriveNumber))) //Not motor ON?
FLOPPY_LOG("FLOPPY: Error: drive motor not ON!")
FLOPPY.commandstep = 0xFF; //Move to error phase!
return;
FLOPPY.ST0.UnitSelect = FLOPPY.DOR.DriveNumber; //Current unit!
FLOPPY.ST0.CurrentHead = (FLOPPY.commandbuffer[2] & 1); //Current head!
FLOPPY.ST0.NotReady = 1; //We're not ready yet!
FLOPPY.ST0.UnitCheck = FLOPPY.ST0.SeekEnd = FLOPPY.ST0.InterruptCode = 0; //Clear unit check and Interrupt code: we're OK. Also clear SE flag: we're still busy!
if (readdata(FLOPPY.DOR.DriveNumber ? FLOPPY1 : FLOPPY0, &FLOPPY.databuffer, FLOPPY.disk_startpos, FLOPPY.databuffersize)) //Read the data into memory?
FLOPPY.ST0.SeekEnd = 1; //Successfull read with implicit seek!
FLOPPY_startData();
else //DSK or error?
if (DSKImageFile = getDSKimage(FLOPPY.DOR.DriveNumber ? FLOPPY1 : FLOPPY0)) //Are we a DSK image file?
if (readDSKSectorData(DSKImageFile, FLOPPY.commandbuffer[3], FLOPPY.commandbuffer[2], FLOPPY.commandbuffer[4], FLOPPY.commandbuffer[5], &FLOPPY.databuffersize)) //Read the data into memory?
if (readDSKSectorInfo(DSKImageFile, FLOPPY.commandbuffer[3], FLOPPY.commandbuffer[2], FLOPPY.commandbuffer[4], &sectorinformation)) //Read the sector information too!
FLOPPY.ST1.data = sectorinformation.ST1; //Load ST1!
FLOPPY.ST2.data = sectorinformation.ST2; //Load ST2!
FLOPPY_startData();
return; //Just execute it!
//Plain error!
FLOPPY.ST0.data = 0x80; //Invalid command!
FLOPPY.commandstep = 0xFF; //Error!
void floppy_writesector() //Request a write sector command!
FLOPPY_LOG("FLOPPY: Write sector: Sector size: %i bytes", FLOPPY.databuffersize)
FLOPPY_LOG("FLOPPY: Write sector #%i", FLOPPY.disk_startpos) //We're reading this sector!
FLOPPY_LOG("FLOPPY: Write sector: CHS=%i,%i,%i; Params: %02X%02X%02x%02x%02x%02x%02x%02x", FLOPPY.commandbuffer[3], FLOPPY.commandbuffer[2], FLOPPY.commandbuffer[4], FLOPPY.commandbuffer[1], FLOPPY.commandbuffer[2], FLOPPY.commandbuffer[3], FLOPPY.commandbuffer[4], FLOPPY.commandbuffer[5], FLOPPY.commandbuffer[6], FLOPPY.commandbuffer[7], FLOPPY.commandbuffer[8]); //Log our request!
return;
FLOPPY.ST0.data = ((FLOPPY.ST0.data & 0x3B) | 1) | ((FLOPPY.commandbuffer[3] & 1) << 2); //Abnormal termination!
return;
FLOPPY_startData(); //Start the DMA transfer if needed!
void floppy_executeData() //Execute a floppy command. Data is fully filled!
switch (FLOPPY.commandbuffer[0] & 0xF) //What command!
//Write sector to disk!
updateFloppyWriteProtected(1); //Try to write with(out) protection!
if (FLOPPY.databufferposition == FLOPPY.databuffersize) //Fully buffered?
if (writedata(FLOPPY.DOR.DriveNumber ? FLOPPY1 : FLOPPY0, &FLOPPY.databuffer, FLOPPY.disk_startpos, FLOPPY.databuffersize)) //Written the data to disk?
switch (floppy_increasesector(FLOPPY.DOR.DriveNumber)) //Goto next sector!
case 1: //OK?
//More to be written?
floppy_writesector(); //Write another sector!
return; //Finished!
case 2: //Error during transfer?
//Let the floppy_increasesector determine the error!
break;
case 0: //OK?
default: //Unknown?
FLOPPY.ST0.SeekEnd = 1; //Successfull write with implicit seek!
FLOPPY.ST0.InterruptCode = 0; //Normal termination!
break;
FLOPPY_LOG("FLOPPY: Finished transfer of data (%i sector(s)).", FLOPPY.sectorstransferred); //Log the completion of the sectors written!
FLOPPY.resultposition = 0;
FLOPPY.resultbuffer[0] = FLOPPY.ST0.data; //ST0!
FLOPPY.resultbuffer[1] = FLOPPY.ST1.data; //ST1!
FLOPPY.resultbuffer[2] = FLOPPY.ST2.data; //ST2!
FLOPPY.resultbuffer[3] = FLOPPY.commandbuffer[2]; //Cylinder!
FLOPPY.resultbuffer[4] = FLOPPY.commandbuffer[3]; //Head!
FLOPPY.resultbuffer[5] = FLOPPY.commandbuffer[4]; //Sector!
FLOPPY.resultbuffer[6] = FLOPPY.commandbuffer[5]; //Sector size!
FLOPPY.commandstep = 3; //Move to result phrase and give the result!
FLOPPY_raiseIRQ(); //Entering result phase!
else
if (drivereadonly(FLOPPY.DOR.DriveNumber ? FLOPPY1 : FLOPPY0)) //Read-only drive?
FLOPPY.resultbuffer[0] = FLOPPY.ST0.data = ((FLOPPY.ST0.data & 0x3B) | 1) | ((FLOPPY.commandbuffer[3] & 1) << 2); //Abnormal termination! ST0!
FLOPPY.resultbuffer[1] = FLOPPY.ST1.data; //Drive write-protected! ST1!
FLOPPY.resultbuffer[2] = FLOPPY.ST2.data = 0x00; //ST2!
FLOPPY.commandstep = 3; //Move to result phase!
if (writeDSKSectorData(DSKImageFile, FLOPPY.commandbuffer[3], FLOPPY.commandbuffer[2], FLOPPY.commandbuffer[4], FLOPPY.commandbuffer[5], &FLOPPY.databuffersize)) //Read the data into memory?
case 1: //OK?
return; //Finished!
break;
case 0: //OK?
default: //Unknown?
break;
return;
//Plain error!
else //Unfinished buffer? Terminate!
break;
case 0x2: //Read complete track
//We've finished reading the read data!
updateFloppyWriteProtected(0); //Try to read with(out) protection!
if (FLOPPY.databufferposition == FLOPPY.databuffersize) //Fully processed?
case 1: //Read more?
floppy_readsector(); //Read another sector!
return; //Finished!
case 0: //OK?
break; //Everything's loaded ready!
case 2: //Error?
default: //Unknown?
//Set ST0 to error code?
break;
FLOPPY_LOG("FLOPPY: Finished transfer of data (%i sectors).", FLOPPY.sectorstransferred); //Log the completion of the sectors written!
break;
FLOPPY.commandstep = 0xFF; //Move to error phrase!
break;
void floppy_executeCommand() //Execute a floppy command. Buffers are fully filled!
FLOPPY.TC = 0; //Reset TC flag!
FLOPPY.resultposition = 0; //Default: start of the result!
FLOPPY.databuffersize = 0; //Default: nothing to write/read!
if (FLOPPY.DOR.DriveNumber & 2) goto invaliddrive;
FLOPPY_LOG("FLOPPY: executing command: %02X", FLOPPY.commandbuffer[0]) //Executing this command!
floppy_writesector(); //Start writing a sector!
break;
floppy_readsector(); //Start reading a sector!
break;
case 0x3: //Fix drive data/specify command
FLOPPY.DriveData[FLOPPY.DOR.DriveNumber].data[0] = FLOPPY.databuffer[0]; //Set setting byte 1/2!
FLOPPY.DriveData[FLOPPY.DOR.DriveNumber].data[1] = FLOPPY.databuffer[1]; //Set setting byte 2/2!
FLOPPY.commandstep = 0; //Reset controller command status!
//Don't process: we don't need this data!
FLOPPY.ST0.data = 0x00; //Correct command!
break;
case 0x7: //Calibrate drive
//Execute interrupt!
FLOPPY.currentcylinders[FLOPPY.DOR.DriveNumber] = FLOPPY.currentcylinder = 0; //Goto cylinder #0!
FLOPPY.ST0.data = 0x20; //Completed command!
FLOPPY_raiseIRQ(); //We're finished!
break;
case 0x8: //Check interrupt status
//Set result
FLOPPY.commandstep = 3; //Move to result phrase!
//Reset IRQ line!
if (FLOPPY.reset_pending) //Reset is pending?
byte reset_drive = 4 - (FLOPPY.reset_pending--); //We're pending this drive!
FLOPPY.ST0.data &= 0xF8; //Clear low 3 bits!
FLOPPY.ST0.UnitSelect = reset_drive; //What drive are we giving!
FLOPPY.ST0.CurrentHead = (FLOPPY.currenthead[reset_drive] & 1); //Set the current head of the drive!
FLOPPY.resultbuffer[1] = FLOPPY.currentcylinders[reset_drive]; //Our idea of the current cylinder!
if (!FLOPPY.reset_pending) //Finished reset?
FLOPPY.ST0.data = 0x00; //Reset the ST0 register after full reset!
else if (!FLOPPY.IRQPending) //Not an pending IRQ?
FLOPPY_LOG("FLOPPY: Warning: Checking interrupt status without IRQ pending!")
FLOPPY.ST0.data = 0x80; //Error!
FLOPPY.resultbuffer[1] = FLOPPY.currentcylinders[FLOPPY.DOR.DriveNumber]; //Our idea of the current cylinder!
else
FLOPPY_LOG("FLOPPY: Sense interrupt: ST0=%02X, Currentcylinder=%02X", FLOPPY.ST0.data, FLOPPY.currentcylinder)
FLOPPY.resultbuffer[0] = FLOPPY.ST0.data; //Give ST0!
FLOPPY.resultposition = 0; //Start result!
FLOPPY.commandstep = 3; //Result phase!
break;
case 0xF: //Seek/park head
if (FLOPPY.DOR.DriveNumber >= 2) //Invalid drive?
FLOPPY.ST0.data = (FLOPPY.ST0.data & 0x32) | 0x14 | FLOPPY.DOR.DriveNumber; //Error: drive not ready!
FLOPPY.commandstep = 0; //Reset command!
return; //Abort!
if (!has_drive(FLOPPY.DOR.DriveNumber ? FLOPPY1 : FLOPPY0)) //Floppy not inserted?
FLOPPY.ST0.data = (FLOPPY.ST0.data & 0x30) | 0x18 | FLOPPY.DOR.DriveNumber; //Error: drive not ready!
return; //Abort!
if (FLOPPY.commandbuffer[2] < floppy_tracks(disksize(FLOPPY.DOR.DriveNumber ? FLOPPY1 : FLOPPY0))) //Valid track?
FLOPPY.currentcylinder = FLOPPY.commandbuffer[2]; //Set the current cylinder!
FLOPPY.ST0.data = (FLOPPY.ST0.data & 0x30) | 0x20 | FLOPPY.DOR.DriveNumber; //Valid command!
FLOPPY_raiseIRQ(); //Finished executing phase!
return; //Give an error!
//Invalid track?
FLOPPY.ST2.data |= 0x4; //Invalid seek!
FLOPPY.commandstep = FLOPPY.commandposition = 0; //Reset command!
break;
case 0x4: //Check drive status
FLOPPY.resultbuffer[0] = FLOPPY.ST3.data; //Give ST3!
FLOPPY.resultposition = 0; //Start the result!
break;
case 0xA: //Read sector ID
if (readDSKSectorInfo(DSKImageFile, FLOPPY.currenthead[FLOPPY.DOR.DriveNumber], FLOPPY.currentcylinders[FLOPPY.DOR.DriveNumber], FLOPPY.currentsector[FLOPPY.DOR.DriveNumber], &sectorinformation)) //Read the sector information too!
FLOPPY.resultbuffer[6] = sectorinformation.SectorSize; //Sector size!
else
FLOPPY.ST1.data = 0x00; //Not found!
FLOPPY.ST2.data = 0x00; //Not found!
FLOPPY.ST1.NoAddressMark = FLOPPY.ST1.NoData = 1; //We cannot find the ID!
FLOPPY.resultbuffer[6] = 0; //Unknown sector size!
else //Normal disk? Generate valid data!
FLOPPY.ST1.data = 0x00; //Clear ST1!
FLOPPY.ST2.data = 0x00; //Clear ST2!
updateFloppyTrack0(); //Update track 0!
updateFloppyWriteProtected(0); //Update write protected related flags!
if (floppy_LBA(FLOPPY.DOR.DriveNumber, FLOPPY.currenthead[FLOPPY.DOR.DriveNumber], FLOPPY.currentcylinders[FLOPPY.DOR.DriveNumber], FLOPPY.currentsector[FLOPPY.DOR.DriveNumber]) >= (FLOPPY.geometries[FLOPPY.DOR.DriveNumber]->KB * 1024)) //Invalid address within our image!
FLOPPY.ST1.NoAddressMark = FLOPPY.ST1.NoData = 1; //Invalid sector!
FLOPPY.resultbuffer[6] = 2; //Always 512 byte sectors!
FLOPPY.resultbuffer[3] = FLOPPY.currentcylinders[FLOPPY.DOR.DriveNumber]; //Cylinder!
FLOPPY.resultbuffer[4] = FLOPPY.currenthead[FLOPPY.DOR.DriveNumber]; //Head!
FLOPPY.resultbuffer[5] = FLOPPY.currentsector[FLOPPY.DOR.DriveNumber]; //Sector!
break;
case 0x2: //Read complete track!
invaliddrive: //Invalid drive detected?
break;
void floppy_abnormalpolling()
FLOPPY.ST0.data |= 0xD0; //Abnormal termination by polling!
void floppy_writeData(byte value)
byte commandlength[0x10] = {
0, //0
0, //1
8, //2
2, //3
1, //4
8, //5
8, //6
1, //7
0, //8
8, //9
1, //A
0, //B
8, //C
5, //D
0, //E
2 //F
//TODO: handle floppy writes!
switch (FLOPPY.commandstep) //What step are we at?
case 0: //Command
FLOPPY.commandstep = 1; //Start inserting parameters!
FLOPPY.commandposition = 1; //Start at position 1 with out parameters/data!
FLOPPY_LOG("FLOPPY: Command byte sent: %02X", value) //Log our information about the command byte!
switch (value) //What command?
FLOPPY.commandbuffer[0] = value; //Set the command to use!
floppy_executeCommand(); //Execute the command!
break;
case 0x22: //same
case 0x42: //same
case 0x62: //same
case 0x45: //same
case 0x85: //same
case 0xC5: //same
case 0x26: //same
case 0x46: //same
case 0x66: //same
case 0x86: //same
case 0xA6: //same
case 0xC6: //same
case 0xE6: //same
break;
default: //Invalid command
break;
break;
FLOPPY_LOG("FLOPPY: Parameter sent: %02X(#%i/%i)", value, FLOPPY.commandposition, commandlength[FLOPPY.commandbuffer[0] & 0xF]); //Log the parameter!
FLOPPY.commandbuffer[FLOPPY.commandposition++] = value; //Set the command to use!
if (FLOPPY.commandposition > (commandlength[FLOPPY.commandbuffer[0] & 0xF])) //All parameters have been processed?
floppy_executeCommand(); //Execute!
break;
break;
case 2: //Data
switch (FLOPPY.commandbuffer[0]&0xF) //What command?
case 0xD: //Format track
FLOPPY.commandbuffer[FLOPPY.databufferposition++] = value; //Set the command to use!
if (FLOPPY.databufferposition==FLOPPY.databuffersize) //Finished?
floppy_executeData(); //Execute the command with the given data!
else if (FLOPPY.DOR.Mode) //DMA mode and not completed?
FLOPPY_dataReady(); //We have data ready to transfer!
if (FLOPPY.TC) //Terminal count? We're ending too soon!
else //Non-DMA mode and not completed?
break;
floppy_abnormalpolling(); //Abnormal polling!
break;
break;
case 3: //Result
break; //We don't write during the result phrase!
case 0xFF: //Error
//We can't do anything! Ignore any writes now!
break;
default:
break; //Unknown status, hang the controller or do nothing!
byte floppy_readData()
byte resultlength[0x10] = {
0, //0
0, //1
7, //2
0, //3
1, //4
7, //5
7, //6
0, //7
2, //8
7, //9
7, //a
0, //b
7, //c
7, //d
0, //e
0 //f
byte temp;
case 0: //Command
break; //Nothing to read during command phrase!
break; //Nothing to read during parameter phrase!
case 2: //Data
temp = FLOPPY.databuffer[FLOPPY.databufferposition++]; //Read data!
floppy_executeData(); //Execute the data finished phrase!
return temp; //Give the result!
break;
default: //Invalid command: we have no data to be READ!
break;
break;
case 3: //Result
temp = FLOPPY.resultbuffer[FLOPPY.resultposition++]; //Read a result byte!
FLOPPY_LOG("FLOPPY: Reading result byte %i/%i",FLOPPY.resultposition,resultlength[FLOPPY.commandbuffer[0]&0xF])
if (FLOPPY.resultposition>=resultlength[FLOPPY.commandbuffer[0]&0xF]) //Result finished?
return temp; //Give result value!
break;
default: //Invalid command to read!
break;
break;
case 0xFF: //Error
return FLOPPY.ST0.data; //Give ST0, containing an error!
break;
default:
break; //Unknown status, hang the controller!
return ~0; //Not used yet!
byte PORT_IN_floppy(word port, byte *result)
if ((port&~7) != 0x3F0) return 0; //Not our port range!
byte temp;
switch (port & 0x7) //What port?
case 0: //SRA?
temp = 0;
if (FLOPPY.IRQPending) temp |= 0x80; //Pending interrupt!
*result = temp; //Give the result!
return 1; //Not used!
case 1: //SRB?
*result = 0;
case 4: //MSR?
updateFloppyMSR(); //Update the MSR with current values!
*result = FLOPPY.MSR.data; //Give MSR!
return 1;
case 5: //Data?
//Process data!
*result = floppy_readData(); //Read data!
return 1;
case 7: //DIR?
updateFloppyDIR(); //Update the DIR register!
*result = FLOPPY.DIR.data; //Give DIR!
return 1;
default: //Unknown port?
break;
return 0; //Unknown port!
byte PORT_OUT_floppy(word port, byte value)
if ((port&~7) != 0x3F0) return 0; //Not our address range!
case 2: //DOR?
FLOPPY.DOR.data = value; //Write to register!
if (!FLOPPY.DOR.REST) //Reset requested?
FLOPPY.DOR.REST = 1; //We're finished resetting!
FLOPPY_reset(); //Execute a reset!
return 1; //Finished!
case 4: //DSR?
if (value & 0x80) //Reset requested?
value &= 0x7F; //Clear the reset bit automatically!
FLOPPY.DSR.data = value; //Write to register!
case 5: //Data?
floppy_writeData(value); //Write data!
return 1; //Default handler!
case 7: //CCR?
FLOPPY.CCR.data = value; //Set CCR!
return 1;
break; //Unknown port!
//DMA logic
void DMA_floppywrite(byte data)
floppy_writeData(data); //Send the data to the FDC!
byte DMA_floppyread()
return floppy_readData(); //Read data!
void FLOPPY_DMADREQ() //For checking any new DREQ signals!
DMA_SetDREQ(FLOPPY_DMA, (FLOPPY.commandstep == 2) && FLOPPY.DOR.Mode); //Set DREQ from hardware when in the data phase and using DMA transfers and not busy yet(pending)!
void FLOPPY_DMADACK() //For processing DACK signal!
FLOPPY.DMAPending = 0; //We're not pending anymore!
void FLOPPY_DMATC() //Terminal count triggered?
FLOPPY.TC = 1; //Terminal count triggered!
void initFDC()
memset(&FLOPPY, 0, sizeof(FLOPPY)); //Initialise floppy!
//Initialise DMA controller settings for the FDC!
DMA_SetDREQ(FLOPPY_DMA,0); //No DREQ!
registerDMA8(FLOPPY_DMA, &DMA_floppyread, &DMA_floppywrite); //Register our DMA channels!
registerDMATick(FLOPPY_DMA, &FLOPPY_DMADREQ, &FLOPPY_DMADACK, &FLOPPY_DMATC); //Our handlers for DREQ, DACK and TC!
//Set basic I/O ports
register_PORTIN(&PORT_IN_floppy);
register_PORTOUT(&PORT_OUT_floppy);
register_DISKCHANGE(FLOPPY0, &FLOPPY_notifyDiskChanged);
register_DISKCHANGE(FLOPPY1, &FLOPPY_notifyDiskChanged);
UniPCemu Git repository
