First post, by computergeek92
I recently found my oldest x86 PC yet - The SWAN XT10 with an 8088 cpu at 10MHz, 640K memory, and a 20MB hard drive! I havent fully tested the PC because it is missing other add on cards and i'm new to XT class hardware. It was also missing one of the 5.25 floppy drives so I installed a black 1.2MB one to it. How much text docs can you fit on one of those 1.2MB drives or the older 360K version? I was thinking on swapping out the hardware and build a custom hot rodded 386 using the XT case, but I just can't bring myself to disturb this precious and rare computer! 😊 So... besides using it for 80's DOS games and word processing, what else could I use this PC for? Or is it truly a relic..? (Please don't say doorstop)
    487.56 KiB
Dedicated Windows 95 Aficionado for good reasons:
http://toastytech.com/evil/setup.html
Reply 1 of 25, by mateusz.viste
What about playing music? I mean, MIDI music of course. You can fit plenty of 'em into that 20M hard drive of yours.
You'd need to invest into an external synth for that, tough (with serial connectivity, since there is no chance for an MPU-401 interface on such PC).
Reply 2 of 25, by Dropcik
Id say use it to get onto some old bbs's. There are still plenty of them out there you can still get on. The problem is getting the computer to get online. If you still have a phone line you can get a modem and configure a program like telix to get on a bbs. For machines like this, I find it easier to use a serial port to a newer computer with an Ethernet connection to do the work of a modem for me. I think the program is called internet modem, id have to look it up when I get home. But it simulates a serial modem with all its modem commands. The only thing you would need is a null modem cable for it to work, as regular serial cables don't work.
Ayy LMAO
Reply 3 of 25, by Jorpho
Those will all work perfectly fine with any Windows terminal program, though.
Reply 5 of 25, by computergeek92
LoL putting this pc online when it came out before the internet? ha ha
Reply 7 of 25, by oerk
Not internet. BBS. Perfectly legit for a machine from this era.
And because I'm not done nitpicking, the Internet exists since the late 60s. You're thinking of the World Wide Web or the HTTP protocol respectively.
Reply 8 of 25, by Robin4
Scali wrote:
That case is actually an IBM AT-lookalike, rather than a PC/XT: http://www.old-computers.com/museum/computer.asp?c=185&st=1
Yes it looks like an AT, but these cases where also used for XT class computers back in the days
If you look good to the case logo its says XT10.. I bet this is the Original XT case with the Original motherboard inside.
I really recommend to keep it Original.
Reply 9 of 25, by Scali
Yup, a friend of mine had a V20-powered XT-class machine in a case such as this as well.
Funny enough there is also the 5162 PC/XT 286 from IBM, which is more of an AT-class machine in an XT case 😀
http://ksinfos.perso.sfr.fr/Collection/comput … %20xt%20286.htm
Reply 10 of 25, by sliderider
Wrong. The internet did not exist in the 1960's. ARPANET existed in the 1960's and it was originally for military and government use only. Saying that the internet existed in the 1960's because of ARPANET is like saying Alexander Graham Bell invented the iPhone.
Reply 11 of 25, by computergeek92
Thank you friends. Now my next question is: Would any 386 cpu play all 8088 games (early 80's or newer) without any compatibility or speed problems? (Games running too fast on the 386) And if the 386 is KING, then I may just sell this XT-10.
Reply 12 of 25, by computergeek92
If i'm remembering correctly, I believe that the Internet as we know it was invented in 1992, A.K.A. my birth year. 😀
Reply 13 of 25, by alexanrs
I'm sure there are some timing-sensitive games (need an exact 4.77MHz 8088 processor to run 100% correctly), but I can't remember any. Demos should be easy enough to find. Also, CGA games that use tricks to get more colors on the composite NTSC output. All of these would probably require you find a way to dial back your processor to 4.77MHz though.
Reply 14 of 25, by Jorpho
A much better question is, do you actually want to play any of those 8088 games? The PC software of that era was generally vastly inferior to what you could get for other platforms. And in fact 10 MHz is already a little too fast for some of the oldest games. (Things like the strangely popular Janitor Joe or the rather crummy Striker come to mind – they're a little bit too fast at 12 MHz.)
Reply 15 of 25, by computergeek92
That's where the turbo switch comes in. My best guess is that it goes down to 4.77MHz from 10MHz. No way to test. I don't have any CGA/EGA monitors.
I'd love to try playing 8088 games myself. I saw a video on Youtube and they look cool even with the primitive bleep music.
Reply 18 of 25, by computergeek92
here:
https://www.youtube.com/watch?v=uRoMkKOpSvM
And the sound of an XT booting up sounds so magical:
https://www.youtube.com/watch?v=9-RyvZxKufo
I've always wanted one of those original IBM monitors. Someone out there had a later model one with some kind of vga adapter plugged into a Pentium 1 at 640x480!
Reply 19 of 25, by carlostex
An XT class machine is indeed truly special. It is indeed the most difficult system class to replace, unless you decide to give up on old machines and use DOSBox.
