First post, by superfury
I'm currently testing it with the ATA at port 0x300 using the XTIDE Universal BIOS v2.0.0 beta 3 (ide_xt.bin build) BIOS.
My code is at:
https://bitbucket.org/superfury/x86emu/src
The ATA IDE emulation is in hardware/ide.c.
Anyone knows why the BIOS isn't detecting my ATA device? (I see it's sending a IDENTIFY command and retrieving the result, but after that it says 'not found' with the primary and secondary ATA controller).
UniPCemu Git repository
