New emulator
First post, by vladstamate
Hi,
I have been working on this emulator for a while now. It is not complete and I am still working on it and perfecting it. I was inspired by PCEm so I wanted to create something as modular as that, where you can virtually build a computer from individual parts: CPU, NPU, memory, type, videocard, sound, etc. This is the product:
https://sites.google.com/site/capex86/home
I am a collector of vintage computers/consoles (see https://sites.google.com/site/digiloguemuseum/) so it made sense for me to write an emulator for older computers. I just put the code up on github but I still have a private repository that I mainly work on. However I do not want to break copyright rules (for BIOS, SW, etc) so I am still cleaning that.
There is a lot of work to do still but I wanted to share with the community what I have. Keep watching this space for updates, and thank you for reading!
Vlad.
YouTube channel: https://www.youtube.com/channel/UC7HbC_nq8t1S9l7qGYL0mTA
Collection: http://www.digiloguemuseum.com/index.html
Emulator: https://sites.google.com/site/capex86/
Raytracer: https://sites.google.com/site/opaqueraytracer/
Reply 1 of 8, by Stiletto
Awesome, welcome to the club! (And our forums!) 😁
do the Fandango!" - Queen
Stiletto
Reply 2 of 8, by leileilol
Not even that XT bios written by that ever-so-talented Anonymous or any of the Bochs/QEMU BIOS images?
Reply 3 of 8, by Tertz
You need to notice wich advantages compared to the existing emulators you plan to make. Or it's hard to understand what is it for.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 4 of 8, by vladstamate
For those I provide links on the website to where people can get them. This way I won't be storing an out of date version.
I do not mind distributing Turbo XT BIOS. For example the Bochs BIOS (and the Plex VGA one too) I use a lot in testing when I "build" a 386 in the emulator, but they are easy to get. I have to understand if me distributing those implies I have to distribute their source as well (I do not mind doing that). I figured for the beginning I will just put a link with instructions and improve from there.
Vlad.
Reply 5 of 8, by vladstamate
Oh in order of importance to me:
a) mainly for fun and as a challenge.
b) I want it to be used as a debugging tool for "old DOS" code. That is why I am providing a telnet server connection with commands to inspect the status of the machine, inspect memory, registers, etc. Think of it as an out of band debugger. I also put effort into code disassembly to log files.
c) I like the idea of being able to build a computer from individual parts and see how it goes. Hence the whole philosophy behind this emulator is you specify which parts you want and only those get in. A lot of emulators for example support only VGA. But I wanted MDA, Hercules, CGA all individually supported and not through VGA emulation. It is actually really nice to see a CGA only game not work when I "build" a machine with a Hecrules card only. Same with processors. I can create a V20 based XT machine (which means it won't have a 8402 (PS2) but it will have a 8255 and the V20 will be properly identified (and not as 8086/8088/80186 and so on) but as a V20.
d) I also added in cycle counts per instructions so you can see how it properly behaves. While that does work it is a bit slow as I have not had time improving in.
But really, more is like why not? I thought I can share what I did until now so people can peruse through my code and use what they can. 😀
Vlad.
Reply 6 of 8, by awgamer
If you could get cycle accurate you'd have something, roughly cycle accurate would put you on top, the others I've checked like pcem do specific systems but performance being quite off.
Reply 7 of 8, by Harekiet
Rank DOSBox Author
DOSBox Author
Great effort, looks nice.
And indeed it's much easier to just use the bochs and plex bios. A
Some of the other bioses that pcem supports require more emulation of the controller chips for shadowing roms and mapping ram around.
Although been toying with making another x86 emulator myself and it is kinda nice to try and get some random bios to work. But just writing my own bios is still something I'd like to try as well especially if you remove all the plug n play/pci stuff you don't even have to implement that many features.
Reply 8 of 8, by Scali
Don't forget to emulate that dreaded prefetch buffer!
(Note also that self-modifying code does not affect the prefetch buffer, you can make most emulators crash on that).
