Alphabetical order
First post, by Blades
Ok,I'm probably an idiot. But I use a compact flash drive for my dos machine(thats not the idiot part) so I can transfer crap from my main computer then put it as boot in my dos machine(with IDE to CF converter).
Problem is When I copy stuff over its the last thing that shows up when I do a DIR command. So whatever the last thing I copied it shows up last regardless if its alphabetical or not.
So for example If I copy into my Games directory
Doom
Keen
WOLF3D
on the first pass it shows as above when I do a DIR command. But if I take the card out and add other games such as LOOM and HOCUS it shows up like:
Doom
Keen
Wolf3d
Loom
Hocus
On a regular hard drive I don'[t have this issue, just on any flash card. I know its got to be simple, and I just can't remember how to fix this. Any Help would be appreciated!!! Thanks in advance!!
Reply 1 of 2, by JayCeeBee64
Rank Retired
Retired
DIR /O lists all drive contents in alphabetical order (directories first).
To make this the default, add SET DIRCMD=/O to autoexec.bat.
This link has more info and options for DOS DIR command:
http://www.computerhope.com/dirhlp.htm
Ooohh, the pain......
Reply 2 of 2, by Blades
That was it. Thank you! I knew there was a way just couldn't remember. Need to brush up on my Dos skills some more. Been so long since I've used them. Thanks again!
