First post, by Imperious
Hi All.
I'm not a noob as far as setting up a floppy Dos boot goes, and have just created my first menu system after years of using multiple
disks with different configs.
My question has to do with Access of the Floppy drive after booting has finished. Quite often the game or whatever is being
run will feel the need to access the floppy again, which of course slows everything down. My question is what, if anything can
be added to Autoexec.bat or Config.sys to avoid this happening?
I prefer the system to boot to Windows (95 or 98se depending on computer) by default. Other alternative is to somehow boot to
Dos from HDD with an option to boot into Windows from there if that's possible with 95 or 98.
PC's from XT 8088, 486, Pentium MMX, K6, Athlon, P3, P4, 775, to current Ryzen 2600.
